RNR, Full Race and Ebay 02 housing testing by Buschur Racing
Old Dec 29, 2005 | 01:25 PM
  #106
Elite Evolution's Avatar
Off-Topic and Umiami80
Old Dec 29, 2005 | 01:36 PM
  #107
Soon2BEVO's Avatar
Originally Posted by matt55
So was the psi set at 22.5 before , then new parts were added and then the psi jumped up 2.5psi . Sorry if this is worded crazy the cold meds are working on me
Yes, my boost was set to 22.5psi with some initial spiking at 23-24 for a half second. First drive after the new parts on and the boost slammed to 25psi and held there before starting to bleed down. However, after than I turned the boost down. Car is spiking 24psi and holding at 22.5 then bleeds to 20psi by 7500 (where I shift).
Old Dec 29, 2005 | 03:39 PM
  #108
EVIL_EVO_VIII's Avatar
I remeber when i had the same Ebay 02 housing on my evo, and when i installed it not only did the turbo spool faster, but i felt a big diference in top end.
Dave,
When are you coming out with a bigger o2 housing?? I want to get one soon and i wana buy the right one
Old Dec 29, 2005 | 03:54 PM
  #109
VTECH8TR's Avatar
Dave,
Miguel,
He is working on one right now . He will post up when it is done.
Old Dec 30, 2005 | 09:26 AM
  #110
Juiced's Avatar
Dave how do you feel the ported and coated stock manifold would do if it were mated to a gt30r or gt35r with the mitsu flange?
Old Dec 30, 2005 | 11:17 AM
  #111
Geoff Raicer's Avatar
im not dave, but those turbos require an "off-center" turbine housing which is not nearly as good as a tangential housing (far worse) and not even as good as an on-center turbine housing. It flows very poorly and is not really that good of an idea... although it *does* work, it just doesnt work that well...
Old Dec 30, 2005 | 12:07 PM
  #112
David Buschur's Avatar
Correct, we are working on trying to further port the stock 02 housing. I'd like to put it back on my car but to be honest, for 15 whp I will keep the Ebay part on until I find something as good or better
Thanks Geoff. I agree completely. Keeping the stock manifold with some off the wall adapter or an inferior turbine housing just insn't ideal.
David Buschur
www.buschurracing.com
Old Dec 30, 2005 | 12:39 PM
  #113
Juiced's Avatar
thanks,
i wasnt talking about a adaptor.... precision sells a gt35r with the mitsu flange. I included the specs below so you could take a look. I tried to find a picture but had no luck. the part # they provide is GT35S-R Mitsu
Whl Dia. Trim A/R Wh Dia. Trim A/R
82mm 56 .70 68mm 84 .63
Old Dec 30, 2005 | 01:46 PM
  #114
Juiced,
Uh, hmmmm......easiest way for me to get around this one, being a PTE dealer is simply tell you that the Mitsubishi flange that they use is based on the old DSM stuff. It won't work on the EVO.
David Buschur
Old Dec 30, 2005 | 01:59 PM
  #115
Juiced's Avatar
thats all i needed to know i was just trying to be a clear as possible.
Old Dec 30, 2005 | 02:03 PM
  #116
Alright. I just ordered 10 of those 02 housings. Since they work I am going to stock them.
Won't make crap on them as I have to buy them just like you guys do but atleast I will have them. Some of you don't want to buy from Ebay and I'm not sure if you all noticed but since my postings the prices have increased.
We'll have them instock probably late next week.
David Buschur
Old Dec 30, 2005 | 02:12 PM
  #117
1slowevo's Avatar
how much for them? does it use the dounut gasket still?
Old Dec 30, 2005 | 02:55 PM
  #118
O.K. here is what I am going to do. I ordered 10 of the housings I have on my car. I am going to get them in here and send them out to have them ceramic coated. The material is thin and the ceramic coating will help longevity and engine bay temps. Besides, then you can't get it on Ebay. We'll offer them for $200. They are about $100 now off ebay with shipping, I think.
1 low mx6, not sure if the stock donut gasket goes on or not. Our downpipe doesn't use the stock donut so it wasn't a concern for us. It does come with new gaskets though.
David Buschur
Old Dec 30, 2005 | 02:57 PM
  #119
VTECH8TR's Avatar
I'll answer this one for Dave. Yes you can use the stock donut gasket. You just take it off your existing stock 02 and put in the new piece.
Old Dec 30, 2005 | 03:24 PM
  #120
Warrtalon's Avatar
Isn't the opening on the Ebay O2 be wider than the one on the stock gasket? Wouldn't you need to modify the stock gasket then? If the Ebay O2 already comes with its own gaskets as DAve said, then I don't think it matters, though.
