RNR, Full Race and Ebay 02 housing testing by Buschur Racing
Old Dec 30, 2005 | 03:30 PM
  #121
EVIL_EVO_VIII's Avatar
Originally Posted by davidbuschur
O.K. here is what I am going to do. I ordered 10 of the housings I have on my car. I am going to get them in here and send them out to have them ceramic coated. The material is thin and the ceramic coating will help longevity and engine bay temps. Besides, then you can't get it on Ebay. We'll offer them for $200. They are about $100 now off ebay with shipping, I think.
1 low mx6, not sure if the stock donut gasket goes on or not. Our downpipe doesn't use the stock donut so it wasn't a concern for us. It does come with new gaskets though.
David Buschur
www.buschurracing.com
So this means it has a better chance of not cracking since it also doenst have the support bracket like the stock one?
Old Dec 30, 2005 | 03:36 PM
  #122
marksae's Avatar
If you use an o2 housing that has no support bracket AND a downpipe that doesn't use a donut gasket AND has no flex section, you're just asking for a cracked o2 housing.
Old Dec 30, 2005 | 03:41 PM
  #123
Soon2BEVO's Avatar
I re-used the stock donut gasket on the Ebay 02. It fit snug!
Old Dec 30, 2005 | 03:43 PM
  #124
Warrtalon's Avatar
The opening on the donut gasket was of equal or larger inner diameter as the inner diameter of the o2 housing opening?
Old Dec 30, 2005 | 04:00 PM
  #125
Soon2BEVO's Avatar
It fit just about the same as on the stock 02 housing. The EBay 02 housing has a bigger outlet because the walls of the outlet are much thinner than that of stock.
Old Dec 30, 2005 | 05:46 PM
  #126
I have the Helix dp and it has no flex section. So i shouldnt buy the o2 housing then? I really want to bc of the good power gains but then again i dont wana be replacing it every few months
Old Dec 30, 2005 | 05:49 PM
  #127
Soon2BEVO's Avatar
You should be OK. I am also using the Helix DP, I did however use the stock donut gasket. My exhaust system doesnt flex AT ALL the way it sits right now. Keep in mind, the factory downpipe does not have a flex section. The spring loaded bolts provide ample vibrational dampening.
Old Dec 30, 2005 | 06:45 PM
  #128
marksae's Avatar
Yeah, downpipes that use the stock donut gasket and spring bolts don't need a flex section since that's what allows exhaust movement when you go over bumps.
Old Jan 4, 2006 | 01:25 PM
  #129
Any updates on the o2 housing Dave?
Old Jan 4, 2006 | 01:41 PM
  #130
EvoTio's Avatar
+1
Old Jan 4, 2006 | 02:38 PM
  #131
David Buschur's Avatar
No updates. I am waiting for the ebay ones to come in to have them ceramic coated and we have not had a chance to port/test ours again.
David Buschur
Old Jan 16, 2006 | 10:14 PM
  #132
EvoTio's Avatar
David Buschur
David, any chance of you testing your ported O2 housing soon? I'm very curious if the extra porting you were thinking of doing will give similiar results to the ebay housing.
Old Jan 16, 2006 | 11:08 PM
  #133
tobz's Avatar
O2
Dips on 1 E-bay, Dave, ceramic coated o2
Old Jan 17, 2006 | 04:26 AM
  #134
S2Kstephen's Avatar
Same here!
Old Jan 17, 2006 | 06:47 AM
  #135
We haven't take the time to port another stock housing yet. It's crazy busy here. We'll get to it eventually.
David Buschur
