View Poll Results: Which exhaust sound do you like the best?
Buschur Racing race muffler.
44
15.49%
Buschur Racing new designed muffler
240
84.51%
Voters: 284. You may not vote on this poll
Sound clips for BR exhausts....poll attached.
Yes, if you don't want our standard rolled tip like is pictured you would have to specify that you want a non rolled tip with it being either angle cut or straight cut. Yes, if it is straight the bottom would stick out about the same amount as the top. JDM style tips are straight cut normally.
I have no pictures of tips like that as we custom make each one when we need it.
David Buschur
www.buschurracing.com
David Buschur
DEF want the black! dave, any word on if thats a go or not? maybe a pic of a prototype so we can see? i was thinking hks carbon TI bc i just love the way it looks with the black can, but you may have sold me on the new exhaust!!
another quck question dave, i have a 2006 MR, and i would be interested in the new style cat back...
since the 2006 has the o2 sensor in the cat and not the mid pipe, if i ordered the new exhaust would i have to plug the hole made for the o2 sensor in the midpipe? or is it not there and it a direct bolt on for the 2006 to the stock cat?
thanks dave!
thanks dave!
ok I'm down... how much for the axle back/muffler & will it bolt up to any piping (for an EVO obivously 3")?Rolled tip
I have an exhaust but was looking for a good axle back to replace the ghettoness of mine.
its all 3" but love your New Rear section.
The mufflers are being built. Should leave no later than next week to us.
We can do the black at no additional charge. It will just be a high temp black paint, keep that in mind.
The EVO9's, we put the bung for the 02 in the catback pipe like on the 8's. IF you are using the stock cat the bung will be plugged, it is handy to have for a wideband.
David Buschur
David Buschur
David Buschur
Yes we can put in an extra bung for you. About $25 for doing this. The bungs are all SS and will come with a plug for you to block it off when you aren't using it.
David Buschur
David Buschur
Nice comparison, anyway to redo the test with the car is under a load?
Reving the engine doesn't sound like a decent test unless the engine is under some kind of load.
Still, the new muffler sound nice
