how to improve power in 2k-4k rpm area?
Old Jan 12, 2006 | 08:09 AM
  #31
KazzEvo8's Avatar
Consider the ported O2 housing as well - David, as usual, is dead-on.
  #32
mike1023's Avatar
man cams so hard to choice from. which sucks.
Old Jan 12, 2006 | 08:37 AM
  #33
mike1023's Avatar
ok ted seems like you know a lot now whats the diff with the lift. like more lift the better or what.
Old Jan 12, 2006 | 08:50 AM
  #34
David Buschur's Avatar
The cam choices aren't that hard. The biggest cam you can run (HKS' biggest) without hurting the idle and driveability with what you are tuning with. That's the choices
David Buschur
www.buschurracing.com
Old Jan 12, 2006 | 08:57 AM
  #35
mike1023's Avatar
David Buschur
hehe it seems hard for me lol maybe im just not sure what they do and feel and want the best in all worlds. and on that note what does lift do for you. i see that hks are 10.5mm lift and others have a lift up to 11.8mm is that better or what lol. and car is not built for every day it is full out race car. going the lines of auto x and road race car.
Old Jan 13, 2006 | 06:18 PM
  #36
TrinaBabe's Avatar
Idle the car higher if it doesnt idle well.... i idle mine at over 1k which seemed high at first but you get used to it very quickly... I dont care if you have square cams... it will idle well at 1.2k
Old Jan 13, 2006 | 06:50 PM
  #37
BMan's Avatar
I drive back roads a lot and run at 2k in 5th quite a bit (about 47mph). I have changed a bunch of stuff to bring up the bottom end torque though. I have Tomei 260 procams (high lift helps build big torque), a Tanabe 2.75" downpipe, Helix hard pipes, and White Rabbit (with TiAl and 10.5 hot side). I can hear the bunny starting to spin up at 2500rpm and am building 12psi by 2700rpm. I still have to pay attension or I will bounce off the limiter because it pulls hard all the way to the top.
No I don't have dyno charts yet, I have a UTEC and I'm going to wait a little longer in hopes they release the latest revision soon.
Old Feb 10, 2006 | 10:53 PM
  #38
EVOlution561's Avatar
i got hks 272's with AEM gears
Old Feb 11, 2006 | 03:06 AM
  #39
Ckjeepin's Avatar
Originally Posted by gsrmin
what should i do to improve power in 2k-4k rpm area?
mods that i have is below..
thanx.
buy a v8
Old Feb 11, 2006 | 08:29 AM
  #40
Blue Evo 8's Avatar
I run the HKS 280's in my car with the intake cam set at +2 and the exhaust cam on the stock gear @ 0...
I am also tuned on alky and AEM EMS
i have plenty of torque, and my torque falls off after 5300 RPM's, so below that I have plenty of torqe for daily driving, my numbers are in my sig
Old Feb 11, 2006 | 10:58 PM
  #41
evoguam's Avatar
So, if I get the mildest cam HKS have, what would that be (numbers)? Do I also need to modify anything else? tks.
Old Feb 12, 2006 | 01:12 PM
  #42
S2Kstephen's Avatar
I have the HKS 280's and HKS cam gears, and I'm running a TurboTrix mail-in flash.
-Have them set at -3/-3 for right now
-No idling issues...no stalling to cutting off
-Idles like V8
-Top end power is incredible
unihappytime
Nov 26, 2013 10:27 PM
k270kmh
18
Apr 20, 2007 04:02 AM
nj1266
Feb 11, 2007 05:29 PM
Hypnoz
Jun 2, 2005 03:37 PM
k270kmh
Jul 21, 2004 08:57 AM
