20G-9 from buschur.
Old Feb 10, 2006 | 08:32 AM
  #151
deadbeatrec's Avatar
Well seeing how i dont drive on a daily basis running race gas, i cant really run more than 22psi. knock is a huge safety factor. i will hand the keys to Al and he will do the rest. i just dont want a blown motor u know.
Originally Posted by kmcconn9
if you are only going to run 22 psi, I doubt the gains will be as substancial as you are hoping for. Especially on pump gas...I am going to guess an increase of 15 hp depending on the tune..make sure you find out what the a/f is after he tunes it...
I was hoping to get up there the same day you were getting it installed but I still have parts on order..
good luck
Old Feb 10, 2006 | 08:49 AM
  #152
TURBODAWG's Avatar
Al,
You tuned my friend Chris (smilely) at the DSM shootout last year, he had a Evo 8 WR. He was on 112 octane Torco fuel. He made 326 whp, within 5 whp of David Buschur's RS 20G car. This was the same car that buschur changed the load numbers and made it make 880 awhp or something crazy. David did it all in fun.
Chris's car had:
264 cams
Works TB
B&B 3" TBE
Buschur Deluxe FMIC with upper Buschur pipe
Profec B spec 2
Dynoflash Custom tune
Ebay O2 housing
Ported stock manifold
HKS DLI2
HKS SSBOV with recirc kit
Walbro 255
Buschur 680 injectors
Chris's car made a best of 326 whp that day
Buschurs' RS 20G car had
Ported head
Ported intake manifold
65 mm throttle body
race FMIC
280 cams
AEM
Ported manifold
Ported O2housing
3" TBE
He was running straight 118 Torco fuel in it at the time
His best run was a 331 whp at the time.
Do you not think that Chris's car with the Evo 8 WR was impressive with those numbers on a flash?
Brian
Old Feb 10, 2006 | 09:08 AM
  #153
the only thing important that im lacking is cams. i wanted to do the turbo first because i thought i would get more bang for buck with the turbo. i guess we will see.
Old Feb 10, 2006 | 09:34 AM
  #154
lbcevo's Avatar
deadbeatrec:
Why don't you have cams? Worried about voidinig your warranty :-)
Old Feb 10, 2006 | 09:36 AM
  #155
lbcevo's Avatar
My bad... just saw your last post re:cams.
Old Feb 10, 2006 | 10:33 AM
  #156
EVO8LTW's Avatar
Cams (including labor) cost less than half as much as the turbo and easily would get you the 25 whp gain that you are looking for. Were you thinking that cams would get you less than 13 whp?
Old Feb 10, 2006 | 10:37 AM
  #157
fury656's Avatar
Interested to see deadbeatrec's results with this turbo. His setup mirrors my own and I was able to make pretty good power on pump gas with the WR-8 (22psi, stock cams, flash). Theoretically these upgraded stock turbos should show positive gains even with the stock cams just by virtue of the fact that they maintain boost pressure to redline that much more effectively. I hope to get some comparable track times/dynojet numbers to clarify my past findings with the WR-8.
Old Feb 10, 2006 | 10:52 AM
  #158
nbpal4000's Avatar
264/264 cams get you about 15whp
Old Feb 10, 2006 | 11:04 AM
  #159
fsugatorbait's Avatar
You dont have cams do you?
Old Feb 10, 2006 | 11:08 AM
  #160
nbpal4000's Avatar
i do actually, hks 264s and according Buschur, 264 is mild set up and get you 15 whp
  #161
DynoFlash's Avatar
Originally Posted by TURBODAWG
Al,
Chris's car had:
264 cams
Works TB
B&B 3" TBE
Profec B spec 2
Ebay O2 housing
HKS DLI2
Walbro 255
Ported head
65 mm throttle body
race FMIC
280 cams
AEM
Ported manifold
Ported O2housing
3" TBE
Brian
I like to think that all of my work is impressive, I certainly work hard at it. Obviously the fact that Smiley is a MASTER car tech and worked hard to get every thing 100% perfect on his car was good evidence that the car was perfectly wrenched. Also, obviously with yor expert assistance he selected some of the very best parts.
I think the main issues for conversation are :
1 - What is the gain with a stock turbo vs WR evo 8 unit
2 - What is the gain between OLD evo 8 WR and the new BR EVO IX 20G Wr ?
3 - Is there any reason at all to buy a OLD Evo 8 WR at all given the new one with the IX cover ?
I think the answers of some of these questions will become much clearer as time goes forward
I only have my own personal observations that the IX cover greatly improves the size and shape of the TQ curve both on the WR and on the stock IX turbo
I guess you also have reached the same conclusion as the car you recently built is using a similar IX covered Wr and not a old evo 8 cover one ?
Old Feb 10, 2006 | 11:12 AM
  #162
DynoFlash's Avatar
Another VARIABLE here on these turbos has been the actuator set up and there is a variation on the actuator on some of these various turbos
I know there is one particular actuator which works the best - I am not sure which one it is after spending a whole weekend swapping about actuators at Buschur's
Old Feb 10, 2006 | 11:22 AM
  #163
You should see more than 15 hp by just bolting them in. Id say a conservative estimate is in the 35whp range with tuning.
Old Feb 10, 2006 | 11:31 AM
  #164
TURBODAWG's Avatar
That was definitely nice work on his car. It was second fastest in the stock appearing class that day. Second only to Davids 20G RS car.
We are in the process of switching smilely's car over to a Evo 9 based WR... The turbo is on its way back to us after going under the knife. So we will have a maxed out HP amount on the Evo 8 WR versus a maxed out Evo 9 WR test. This we hopefully will get done in the next couple weeks.
I definitely concur with you that from this point forth, it would be an ill advised decision for anyone to buy an Evo 8 based 20G or WR considering the much improved compressor housing on the Evo 9. There is just NO downside to the new turbo in my mind. The one we tested on the Evo 9 has the Ti/Al internals and a FP high pressure actuator on it, and it spools up ridiculously fast.
We will also be doing a test on a Evo 9 WR on a stock cammed, stock FMIC Evo 8 MR shortly. This should be good information also.
Proper preload on these high pressure actuators is a very important thing in getting them to hold high boost pressure at 6500 RPM and higher.
Brian
  #165
Maximum Boost's Avatar
Originally Posted by BoostMonster
TURBODAWG,
I seem to remember at the DSM Shootout the White Rabbit being referred to as the "Slow Turtle" while one was on the dyno. Seems kinda funny, now that the truth is known. By the way, WR or 20g-9, doesn't matter you guy's are going to need all the turbo you can get to keep up with the "slow-b-aru" when the gt 30R gets here .
I can't believe he went there..............
