20G-9 from buschur.
Old Feb 10, 2006 | 11:31 AM
  #166
deadbeatrec's Avatar
well with a turbo i can always put some race gas in it, turn up the boost and get more power, with cams i cant do that. thats y i went with the turbo first.
also a lot of people say that anything above 264's u should have a bigger turbo, so i figured i would do that first.
but honestly i think an intercooler is next. just because i can install it myself and there is no tuning involved. i still have to put my coilovers in, so as long as i gain some power with this turbo i will be content for awhile.
Old Feb 10, 2006 | 11:47 AM
  #167
DynoFlash's Avatar
i would suggest that we keep the stock injectors in it for the before and after test as withouit cams you will not need those 780 's - we can always add them when tyou get cams one day ?
Old Feb 10, 2006 | 11:55 AM
  #168
fury656's Avatar
Originally Posted by DynoFlash
Another VARIABLE here on these turbos has been the actuator set up and there is a variation on the actuator on some of these various turbos
I know there is one particular actuator which works the best - I am not sure which one it is after spending a whole weekend swapping about actuators at Buschur's
The actuator is definitely a crucial addition with these turbos. I have the FP HP actuator which holds 18psi at spring pressure. In maintaining 22psi rock solid im able to make up some of the power differential compared to aftermarket cam equipped 03/05 cars and the IX. Expectedly my low-midrange torque is much lower in comparison with the WR making up the differential in the upper range. My HP curve continues to climb to redline while my TQ levels off and stays flat.
Old Feb 10, 2006 | 12:02 PM
  #169
justchil's Avatar
That reminds me .. I wish I would have asked AL when he was tuning my car what my injector duty cycle was on race gas.
Old Feb 10, 2006 | 12:05 PM
  #170
i was told from david that at least 680cc's were needed so i want them in there, i mean i did buy them.
Old Feb 10, 2006 | 12:21 PM
  #171
Nez136's Avatar
on my MR before injectors i had, 272 cams, intake, walbro 255, Megan header, TBE no cat, EBC, IC and a Utec to tune with. I hit 100% duty cycle on the stock turbo
Old Feb 10, 2006 | 03:50 PM
  #172
IE Evo's Avatar
Originally Posted by EVO8LTW
The issue here is not whether this turbo will show a decent gain in the curve and max HP (I think it will, just like the WR8), but rather whether the 20G-9-5 performs better than the WR8 and justifies the price premium. What we need is a WR8 to 20G-9 test with an unbiased tuner.
So true! Also how much credit can be given to the superior design of the IX housing when comparing it to the WR8? BR 20g-8 = WR-8 imo and with the IX design performance will be marginally better for both applications. IMO a good upgrade either way. But is it worth the price and why was the 20g-8 and 20g-9 ever promoted as a superior product if the Vendor and Accomplice knew they were the same thing.
Old Feb 10, 2006 | 03:57 PM
  #173
PVD04's Avatar
They were not the same thing. The 20g-8 and 20g-9 were both 6 blade compressor wheels. I'm pretty sure that's a significant difference. Now the 20g-9-5 that we've all just learned of does seem to have the same compressor wheel as the WR, but I haven't seen anyone with any knowledge on the subject confirm that they are in fact the same wheel. All that was said is that it was a "special version" of the WR. I'm not sure if that means the compressor wheel is slightly different, the turbine is different, both, or neither. I suppose the fact that no one has denied the assumption that both compressor wheels are the same indicates that they are, in fact, the same. I hope my post isn't too confusing, as trying to type what I'm actually thinking (without writing an entire book) is making my head spin.
-Paul
Old Feb 10, 2006 | 04:38 PM
  #174
LuxuryBroker's Avatar
is it or is it not the same?
Old Feb 10, 2006 | 07:40 PM
  #175
EVO8LTW's Avatar
He probably assumed that you had cams. David probably would have tried to dissuade you from getting the 20G if he had known that you had stock cams and weren't upgrading them because you thought the turbo was a better bang for the buck (as opposed to keeping them in for warranty, emissions or some other legitimate reason).
Old Feb 10, 2006 | 09:26 PM
  #176
evolvedmb's Avatar
This has sparked my interest tremendously - * see signature for mods *
Can the WR9 upgrade be accomplished at Buschur's, or will I have to send my WR8 w/ 10.5 hotside back to FP? This may be the solution I am looking for to extract more Hp out of my setup! I am looking for David or Robert to reply if they could on this subject. I can't wait for the results, as I want to see the diff. between the WR8 and WR9 dyno'ed on the same car. Thanks for responding!
Old Feb 10, 2006 | 09:29 PM
  #177
Maximum Boost's Avatar
Originally Posted by BoostMonster
TURBODAWG,
I seem to remember at the DSM Shootout the White Rabbit being referred to as the "Slow Turtle" while one was on the dyno. Seems kinda funny, now that the truth is known. By the way, WR or 20g-9, doesn't matter you guy's are going to need all the turbo you can get to keep up with the "slow-b-aru" when the gt 30R gets here .
You are going to need something bigger than a 30R to catch us dog!!!!
Old Feb 11, 2006 | 01:27 AM
  #178
Spooldyou's Avatar
i replaced my k03 with a k04 but there was no way in hell i got full boost at 1600 rpms. no way. i would hit 20psi and drop to about 18 but no way i would hit that at 1600.
typo ment k03 Chill out Boost police. No need to get angry about it.
Old Feb 11, 2006 | 05:14 AM
  #179
Richard Sierra's Avatar
You have to send it to FP and it's $600 for the upgrade. I don't think it's worth it.
Old Feb 11, 2006 | 06:24 AM
  #180
EVO8LTW's Avatar
Would you have to get a $175 Buschur install kit on top of that? Or does that include everything you need to drop it into an Evo8?
