Cam Gears adjustment
Old Jul 14, 2006 | 03:18 PM
zbomb's Avatar
I'm wondering this as well. For -3,-3 are we talking 3 marks on the gear or 1.5. HKS gears??
Old Jul 14, 2006 | 03:47 PM
Ted B's Avatar
The degree marks on the cam gears are cam degrees, not crank degrees. When we speak of advancing or retarding cams, we speak in cam degrees. 1 cam degree = 2 crankshaft degrees.
Old Jul 14, 2006 | 03:54 PM
zbomb's Avatar
Thumbs up
Awesome, thanks for the info.
Old Jul 14, 2006 | 04:10 PM
got boost??'s Avatar
SO, -3/-3 means, 1.5 marks on the hks gears??
Old Jul 14, 2006 | 04:15 PM
Ted B's Avatar
No, -3/-3 means -3/-3 on the cam gears. We adjust cams in cam degrees. When we speak of cam specs (degrees duration, etc.), we express that in crank degrees.
Old Jul 14, 2006 | 04:25 PM
DOHHHH!!!!!!!!!
i was setting them for ej. -3/-3 in 1.5 marks of the gear
Thanks a lot for the input.
Cheers.
Old Jul 14, 2006 | 04:31 PM
Ted B's Avatar
Hmmm, be sure not to use a left-handed screwdriver when you go to change it . . .
Old Jul 14, 2006 | 04:47 PM
Sorry, but what's exactly a left handed screw driver???
BTW, we installed 280 crower cams and i didn't felt any power gains, what can it be???
And finnaly, which is the best setup for max power, never mind turbo lag or low end torque???
thanks a lot.
Old Jul 14, 2006 | 04:51 PM
Ted B's Avatar
Not enough info to comment. We'd need to know everything in your setup. But of course, this begs the first question . . . was the car retuned for the new cams?
Old Jul 14, 2006 | 04:52 PM
ted, i sent you a PM.
Thanks.
Old Jul 14, 2006 | 07:43 PM
Wangracing's Avatar
Understand that cam settings are expressed in cam degrees, but with the HKS cam gears, each notch or marking represents 2 degrees of adjustment apparently. So i guess the clarification I am after is that to achieve say a 3 degree retard, you would go to 1 and a half notches on the gear not three correct?? 3 notches would be 6 degrees yeah??
Old Jul 14, 2006 | 07:51 PM
Ted B's Avatar
Post a photo of one of those cam gears.
TwistedEvo8
26
Aug 7, 2016 06:48 PM
honki24
Dec 20, 2006 09:43 AM
Gsxfury
Oct 9, 2005 08:37 AM
livesports
Dec 2, 2004 08:54 AM
justrick
11
Oct 5, 2004 10:54 PM
