Blew engine today under extremely normal circumstances. not happy.EDITED
Originally Posted by DynoFlash
Anyway - a side point - he changed his oil the day before it blew up - THIS very point is very suspicious and I am suprzed NO ONE has noted this - human error being what it is it is very possible that some mistake may have been made at that point - eg leaking drain plug, worng oil filter - leaking oil filter - low oil - conatmination in oil - etc etc etc
Originally Posted by David@Vishnu
Stew for the good of the community can you start off the thread here https://www.evolutionm.net/forums/sh...hreadid=188126Thanks
**** happens
Originally Posted by 13-0
Umm people give the man the benifit of the doubt that he is smart enough to simply change oil. People are giving you the benifit of the doubt that you were smart enought to load the right map. Lets not cast doubt that the man is dumb after all its much easier for your finger to slip and load the wrong map than it is for him to tighten 1 bolt.
Hmm
Hmm
The point is...anyone can make a mistake, even the factory mechanic. The last time I had major work done under the hood the factory Mitsubishi mechanic installed the BOV backward. It works differently that way.
Stew how many miles did you actually drive the EVO with the MBC and flash. I remember putting the MBC in a couple of weeks ago. It's not like he was driving around for close to a year with all of these mods, hell for most of the EVO's life it only had a TBE. The air intake wasn't even on the car that long.
I recently had an overboost problem that I didn't notice because I was too busy messing around. The short of it is I hit 28PSI on 93 octane fuel. The result is every time my BOV vents it now pukes oil, I figure the rings are history. I have had a lot of mods on my car since 2004 and had no trouble, until now, with the light mods similiar to the ones stew had on his EVO even in the coldest weather.
His very lean, for a Subaru atleast, 12 to 1 A/F Ratio from 6800RPM on is only a problem when he is up in that RPM range. Driving at 80mph he would probably be around 3200RPM, total guess here, so the lean a/f ratio shouldn't have had any affect on the engine considering that Stew was driving at lower RPM's. The EVO should have been able to keep the A/F ratios in check by using it's MAF and O2 sensors to adjust fuel because he wasn't at WOT when the motor blew.
Basic mods can change the way an engine takes in and releases air which is why at WOT you need to be tuned for the increase in air taken in by the engine. Closed loop mapping, which I think is WOT but I could have these two mixed up, relies on the hard mapping for fuel and timing. Open loop, which I think takes input from the MAF and the O2 sensors to determine fueling to maintain a proper A/F ratio, should be able to control the A/F ratio so the car doesn't run lean even if the car has an intake and a TBE because you haven't really increased boost or changed the volume of air moved by the turbo.
I think that this was a problem that Stew has had for some time and it just let itself be know now and went bang in a hurry. If Stew had all of the parts on for a good period of time and not a short couple of weeks I would support the "You messed it up crowd", BUT given the short period of time and the highway driving I just can't see any of the mods generating this much damage.
I looked inside the huge hole in the front of Stew's block and could see the bottom of the number 1 piston, it looked like it had the rod ripped out of it. The entire lower section of the piston was missing and little chunks of aluminium were all over the belly splash pan under the engine. The number 2 piston looked fine except for the top half of the connecting rod dangleing from it. We removed the spark plugs to take a look at the top of the pistons, I know that you really can't see much but I little peak is better than none at all. The number 1 piston was much cleaner than the number 2 piston and I couldn't see any visible damage to the piston tops.
I still think is was an oil pressure related problem and not the result of the flash or any of the mods on the car.
Originally Posted by DRWN KIX
I had a factory first service on a new Volvo once. Checked the oil when I picked it up. Looked under the car, everything looked fine. Drove it 80 miles before the rear end locked up solid on the freeway at 60 mph towing a light trailer with my road race motocycle on it. Things were very dramatic for the next minute. I ended up off the side half in the dirt. I looked under the car. No drain plug in the differential.
Originally Posted by bigfishs
I have noticed a clicking noise coming from the dash onm the drivers side, comes and goes under certain rpm. Only started recently. Someone said that could be the crank or the rods. Was this happened to you?
Sorry to hear what happened. Any chance of putting it back to stock and letting the dealer fix it? Assuming the failure wasnt your fault
Be careful and get everything checked out. You both have similar mods and tuning. Or you might end up with the same blown engine.
Originally Posted by Stew
Well I finally got a few HIGH RES pictures of the "very fine shavings" inside the head.
discuss
discuss
someone earlier in this thread said something to the effect
1) run lean by those crazy high AFR's and high boost levels @ 7000+
2) the situation stated in #1 (which you clearly admit too) caused detonation, or caused many small detonations over time stretching the rod bolts.
3) rod bolts stretched, causing premature wear on the bearings.
4) bearings fail, bottom end goes boom...
I really think that the cold weather contributed to the failure. With the boost levels you were running combined with that wonderful winter crap gas you get in CT during the winter months (it's like the CA crap gas we get out here) probably lead to an unsafe condition. I am not saying it caused the problem, but it definately contributed to the failure.
I don't see how warrentee could even possibly apply, not even covered by magnus-moss because you modded the motor and other systems required to make if function properly within
specs..good luck.
Originally Posted by 4G63>OOOO
No, you're not, but it's much easier to blame Mitsu and try to scam a free engine instead of being a man and owning up to what you did.
^ Agreed! Like I said if not for the short period of time that Stew was driving the car with the MBC and the flash I would blame long term abuse as the cause too.
Fact is that the car has only 15K on it and most of that time it only had a TBE!
Look at your own cars and tell me how long you have had an exhaust on it for.
Just to clear something up, the intake, MBC and the flash were all recent additions to his car.
This thread contains two remarks having equal lacking of truth
1)
2)
1)
Originally Posted by evo_08
its george bush fault
Originally Posted by thaigurlygirl
You think your flash might have been related to engine failure... YES
Originally Posted by yellowmars
ah, it's so refreshing...
...to see how Al is bashing yet another person...even though he always says "I AM NOT saying anything negative."
But read from beginning and you'll see something, as soon as the person with the blown engine mentions his car was flashed by a particular vendor, the vendors competition (nemisis) suddenly has interest to the thread remarking friendly suggestions and stating 12.1 is way too lean, etc.etc - as if his tuning sales will start to improve.
All I can say is that mail-ins are so week in the first place and the car would have made the same AF tuned or not? Maybe the FP is overheating
I just thought the suggestive tuner's (coughshivcough)opportunistic behavior was hillarious.
