Blew engine today under extremely normal circumstances. not happy.EDITED
Old Mar 9, 2006 | 03:36 PM
  #331
DynoFlash's Avatar
Originally Posted by evo637
I do think the rod bolts only become weak due to modifications and the bypass of important safety function of the ecu. ie MBC, revlimiter. We can all speculate all the weak points but the fact of the matter is that mitsubishi engineers know what there doing and have spent countless of years perfecting the 4g63.
Your assertion is totally incorrect
The reported number of 100% BONE stock evos which have failed rods is about equal to that of reflashed ecus.
There have been more AEM cars than any other kind which have failed which I suspect may be due to the higher user defined rev limit
The bottom line is that these are cheaply made made prodcued cars made right along side the normal Lancer in the same facility, you would be suprized how few difefrences there are in the lancer vs. the evo in the production line
In any event the ROD and HEAD bolts are not even TQ'd to spec they are rotated 90 degrees to put them under a constant load per factory spec
What amazes me about the evos is not how bad the rod bolts are - but rather how strong the rest of the motor is. I have not seen ONE crank break thus far and the block also seems very robust.
The weak links in the evo are head and rod studs - oil pump and pistons
The oil pump and pistons only start to have problems after you start to modify the car
However, the rod issue has happend on dozens of stock cars and is without a doubt an item in which the part is not up to task
Old Mar 9, 2006 | 03:38 PM
  #332
DynoFlash's Avatar
Also consider the fact that a company such as Bently or AMG or NSX adopts practices where one master engine builder assemples each complete engine BY HAND
ONE MAN per engine start to finish
One would expect that mistakes are made in mass produced cars which are built on a lancer assemply line
PS- the lancers also have many reports of rod bearing failures as well
Old Mar 9, 2006 | 04:06 PM
  #333
Ted B's Avatar
Originally Posted by Wheelhaus
The engine is designed for spirited driving, but not abuse.
"Abuse" = key word
The engine is designed to run efficiently and make good power in a compact package, with acceptable longevity, at a cost that's justifiable to the accountants. It isn't designed to withstand the abuses of racing, nor to support extraordinary power levels. Quite frankly, I'm amazed those cast pistons hold up as well as they do, at the piston speeds to which they are subjected. I'm equally amazed to find them in this motor in the first place. Even my '86 SVO Mustang had forged pistons from the factory.
Andrew (Dyno4mance) and I were discussing a recent demonstration, where someone independently generated some very convincing evidence to support his theory that the weak link in a Subie motor is in fact the softness of the factory bearings. Could it be possible the EVO motor isn't fitted with the best bearings for big power? I don't know, but someone who puts his hands on both the Mitsu factory bearings and better aftermarket types may be able to shed a little insight.
Old Mar 9, 2006 | 04:34 PM
  #334
Noize's Avatar
EvoM Administrator
I agree with this statement 100%.
The clutch, transfer case, and synchronizers are weak links too, but they aren't part of the engine.
Old Mar 9, 2006 | 04:46 PM
  #335
Stew's Avatar
new thread up with top end pics: https://www.evolutionm.net/forums/sh....php?p=2885919
Old Mar 9, 2006 | 05:10 PM
  #336
Greg K's Avatar
closed after speaking with Stew. Please post any new thoughts in the follow on thread referred to above. And if you want to cause inter-vendor fights, don't bother posting at all.
aziankingz
For Sale - Cars For Sale
Dec 3, 2012 06:49 PM
Stew
Apr 10, 2007 03:22 PM
Stew
Aug 1, 2006 10:40 AM
Stew
Jun 20, 2006 09:33 PM
Stew
Oct 14, 2005 07:40 AM
