Changing IC piping for POWER!?
Old Mar 8, 2006 | 11:37 AM
Warharan's Avatar
This question is about changing the upper and lower IC piping while keeping the stock IC. Are there any substantial power gains by changing the LOWER IC piping. I know Injen has some dyno sheets to show a difference with their intake and upper piping kit, but what about the lower? Thanks.
Warrtalon's Avatar
The LICP can give you around 7-10whp along with quicker spool, but the UICP doesn't help.
Old Mar 8, 2006 | 11:46 AM
boomn29's Avatar
Check out AMS's site. They claim the Lower IP gives between 7-10hp (not whp like stated above). I can attest to definite throttle response. Not 100% sure on the upper piping, but it can hurt.
Think of it like this, you're eliminating bottlenecks and increasing the rate of airflow. Just like exhaust...
Oh, and for most of our levels of mods, an intake upgrade actually degrades performance. Do your research.
Old Mar 8, 2006 | 12:45 PM
Danny23's Avatar
i,m waiting for buschur to make a lower ICP for the IX. i know i can get one from another dealer but its nothing but buschur parts for this car. 06BR350#005
Old Mar 8, 2006 | 12:49 PM
bluebanana23's Avatar
off subject but is this your lil bro warrtalon? I just thought his user name was .
Old Mar 8, 2006 | 12:56 PM
gsujeff55's Avatar
stock turbo, stock intercooler.....upper IC pipe won't do much for you, lower IC will help, and a K&N filter and maf pipe will hurt your performance, especially on the road course when underhood temps get crazy hot.
Old Mar 8, 2006 | 02:14 PM
Warharan's Avatar
You think replacing the lower IC pipe with the Injen lower pipe kit and just dropping an HKS panel filter in the box is the best?
Old Mar 8, 2006 | 02:29 PM
Warrtalon's Avatar
Don't do the HKS filter - it is not re-usable and must be replaced. Use the K&N or Works for your drop-in filter, and instead of messing with Injen, go with one of our leading vendor LICPs: Buschur, AMS, or Nisei.
Old Mar 8, 2006 | 02:50 PM
Ted B's Avatar
After seeing the oily residue a K&N tends to leave inside the MAF, I wouldn't use one.
Old Mar 8, 2006 | 02:52 PM
boomn29's Avatar
You've gotta try to clean it off first....somehow. Best way I've found, buy one that's slightly used! Then use an air compressor to make it 'like new'.
I know that's a half-arsed way to go about it, but it'd work.
Old Mar 8, 2006 | 03:32 PM
Danny23's Avatar
never use an air comp. on a k/n filter. even k/n says not to use compressed air. and the mess comes from people who use too much oil when re-oiling they,re filter
Old Mar 8, 2006 | 04:08 PM
Warharan's Avatar
I'd like to get matching upper piping too, but with all those kits you mentioned, you have to use the mini battery.
Old Mar 8, 2006 | 04:18 PM
Eclipsed Evo's Avatar
The Injen kit works great plus you can leave the battery where it is.
thelza23
17
Oct 4, 2007 03:18 AM
silver evo8
Jun 4, 2007 09:42 AM
jvans04
Feb 10, 2007 08:36 AM
yesevo
24
May 11, 2005 02:05 PM
ZeroFrost
Jan 16, 2004 01:42 PM
