Got my numbers...
Old Mar 10, 2006 | 03:58 PM
DynoFlash's Avatar
I recomend 20.5 ACTUAL boost peak for pump gas mail in tunes
if you maintain that level of boost with the way the stock ecu works i think it would be very hard to hurt anything even if you tried
With custom tuning when i can check everything and we see how the individual car is running I go to 22 psi spike often - if the fuel supports it
Old Mar 10, 2006 | 04:52 PM
Ludikraut's Avatar
Originally Posted by scorke
Don't lots of tuners say about 22 ish is the safe max for pump?
Scorke
Again it depends on how your car is tuned. I run 22-23 psi on 93 octane, but I can guarantee that means that I'm running less timing than someone boosting to 20-21 psi.
l8r)
Old Mar 10, 2006 | 04:55 PM
boostedwrx's Avatar
Scorke
Yea, but not when you dont retard the ignition timing a little bit. Different tuners have different approaches to tuning I think.
Old Mar 11, 2006 | 12:09 PM
evouser12's Avatar
THink i found the problem...my boost is spikin at 21 like it is spose to..but its droppin to around 16-17 and that is to low..should be holding around 18-19..i have the turbosmart MBC, im selling that and i just ordered the FOrge UNOS
Old Mar 12, 2006 | 11:46 AM
Smogrunner's Avatar
That isn't unusual or the problem: Here is a graph of boost on a car that did 11.9 at 115 in the 1/4 mile with boost set at its maximum level. As you can see, the boost dropped to 17psi at 7200rpms. This car did 372whp/357wtq on a dynojet:
Old Mar 12, 2006 | 12:04 PM
IE Evo's Avatar
Originally Posted by Smogrunner
That isn't unusual or the problem: Here is a graph of boost on a car that did 11.9 at 115 in the 1/4 mile(with a retard driving) with boost set at its maximum level. As you can see, the boost dropped to 17psi at 7200rpms. This car did 372whp/357wtq on a dynojet:
Yeah, if this tool can do an 11.9 at 115 mph, just think what a real driver could do.
Old Mar 12, 2006 | 02:03 PM
evouser12's Avatar
I should be holding 18.5-19PSI till about redline if im spiking at 21-22 with my setup...i shouldnt be dropping to 16-17 strating at 21-22PSI becuase that is a HUGE drop which would make sense in my lose of power
Old Mar 12, 2006 | 02:29 PM
Smogrunner's Avatar
Wrong,
Then how do you explain an 115mph Evo that peaks at 26.5 and tapers to 17psi? Boost taper is totally normal in stock turboed Evos. That is not your problem. Do a search.
Old Mar 12, 2006 | 03:13 PM
evouser12's Avatar
i DID do a search and talked to many people...and i kno boost taper is normal, i was told if im spiking at 21-22 i should taper down to 18-19 not 16 with my MBC
Old Mar 12, 2006 | 03:44 PM
Smogrunner's Avatar
Ok,
Here are a few links to stock turbo Evos that show boost levels in the range you are talking about and there is nothing wrong with their cars:
1. https://www.evolutionm.net/forums/sh...d.php?t=188930 Taper to 16 psi
2. https://www.evolutionm.net/forums/sh...d.php?t=180886 Taper to 17 psi
3. https://www.evolutionm.net/forums/sh...d.php?t=180889 Taper to 17 psi
4. https://www.evolutionm.net/forums/sh...d.php?t=180883 Taper to 16 and 17.75
5. https://www.evolutionm.net/forums/sh...d.php?t=181032 Taper to high 16 psi
So you know, I just took the first 5 dyno charts I could find off of the only dyno on Evom that regularly logs and posts boost levels. Take it for what it is worth and good luck finding out why you are making less power than you should be...
Old Mar 12, 2006 | 04:23 PM
evouser12's Avatar
rd
Ok,
thanx smog....well i get my new MBC early this weekend and installed...so ill see what it does...if it doenst do nethin different then i guess im just plain screwed always problems with my car
kirkklau
36
Mar 10, 2017 01:05 PM
akinnear03
Jun 24, 2010 11:22 AM
SuperchargedGTZ
13
Apr 24, 2007 03:28 PM
jonathanVIII
Jul 8, 2006 10:25 AM
nonmature
Sep 11, 2004 02:37 PM
