4g64 2.1L Build Up
Old Apr 12, 2006 | 10:00 AM
  #46
SuperHatch's Avatar
Originally Posted by Ted B
What's interesting about the 2.1L vs. a 2.0L aside from the nominal 5% increase in displacement is the fact that the 2.1L uses the same 88 mm stroke with a longer rod, which would theoretically improve the potential for high rpm efficiency. This option is perhaps best suited for those who intend to wring lots of rpm out of it for the purposes of being able to stay in 4th gear for dragstrip racing with a big turbo and enough power to run 125+ mph traps. This setup would make good use of head porting, long duration cams, and an aftermarket intake manifold with shorter runners, all of which will be most helpful toward maintaining the flattest possible torque curve in the upper rpm ranges, which directly increases high rpm hp.
Rod/Stroke ratio comparison:
4G64 w/ 4G63 crank - 2.1L - 1.77
4G63 - 2.0L - 1.71
4G63 w/ 4G64 crank - 2.3L - 1.5
In contrast, the small rod/stroke ratio of the popular 2.3L stroker will give the greatest mechanical efficiency at low and midrange rpm, which makes it best suited for street action and road racing, where transient response and a wide powerband are most useful.
Using the 4G64 block also gives you more options on wrist pin location since the taller deck height lets you play with rod length more, this is a trouble spot on the stroked 4G63 motors. You can sacrifice some of that rod ratio back to where the 4G63 naturally is but drastically increase the size of your ring lands.
Fun stuff
Old Apr 12, 2006 | 10:23 AM
  #47
joeymia's Avatar
Which Intake Manifold has shorter runners?
Old Apr 12, 2006 | 10:25 AM
  #48
SuperHatch's Avatar
Any of the aftermarket ones....
Old Apr 12, 2006 | 10:26 AM
  #49
joeymia's Avatar
Originally Posted by SlowboyMR
Curt Brown is running one of our 2.1 destroked motors we built for him.. you will see.. we have ran one on our AWD dsm and it took 10k like a champ!
anyone email me if you are interested mas@slowboyracing.com
mark
SBR
BTW do you have any pictures/instruction of the modifications needed for the alternator and water pump for the block? I would love to know what to expect before I drop the block in since this is my daily driver and I will only have friday, saturday, and sunday to get everything working.
Old Apr 12, 2006 | 10:27 AM
  #50
joeymia's Avatar
ahh ok I thought the Magnus and AMS were "long runners"
  #51
Ted B's Avatar
The three that come to mind are the Magnus, AMS, and BJ's. AFAIK, all of those have shorter intake runners and greater plenum volume. That isn't necessarily what you'd want for a street driven car (won't spool as quickly), but fits the bill for drag racing where a large turbo and lots of rpm are required.
Old Apr 12, 2006 | 11:00 AM
  #52
SlowboyMR's Avatar
alt arent a problem.. but you need a shim plate for teh water pump.. Its like 16gs and you will need a 2.4 water pump gasekt to go to the block. then use your 2.0 waterpump.
Mark
SBR
Old Apr 12, 2006 | 12:15 PM
  #53
joeymia's Avatar
Mark
SBR
thanks for the advice.
I will take a ton of pictures when I get to that stage of the build.
Old Apr 12, 2006 | 12:23 PM
  #54
Derek888's Avatar
Originally Posted by Jasil
He's going to need a TRE or Shep trans to make use of all that RPM though. Shifting at 9K+ can be a ***** with a stock trans.
interesting
Old Apr 12, 2006 | 12:44 PM
  #55
joeymia's Avatar
I will most likely only shift at 8k+ going from 3rd to 4th. Right now I take my motor up to 8500 and shift just fine from 3rd to 4th. I have a Tilton Twin Disc, Kartboy Short Shifter, Kartboy Bushings and run Penzoil Syncromesh with some Redline Heavy Duty Shockproof mixed in.
Old Apr 12, 2006 | 12:55 PM
  #56
Evo9"Miss Rose"'s Avatar
Do you people understand how these motors work?
A 4G64 has an 86.5mm bore and 100mm stroke
A 4G63 has an 85.0mm bore and 88mm stroke
The bore is dictated by the piston/block selection.
The stroke is dictated by the crank. The cranks are interchangeable between the two motors.
Stock 4G64:
An 86.5mm piston has a cross sectional area of ~5877mm^2, times 4 pistons is ~23508mm^2, times 100mm stroke is ~2350800mm^3 which is ~2.35L or 2.4L, voila!!!
Stock 4G63:
An 85mm piston has a cross sectional area of ~5675mm^2, times 4 pistons is ~22700mm^2, times an 88mm stroke is 1997600mm^3 which is 1.99L or 2.0L, magic, right!?
To STROKE a 4g63 you put a longer stroke crank in it. A 100mm crank from a 4G64.... do the math again.
4G63 STROKER:
An 85mm piston has a cross sectional area of ~5675mm^2, times 4 pistons is ~22700mm^2, times a new longer 100mm stroke is 2270000mm^3 which is 2.27L or 2.3L, amazing!!!
You CANNOT DEstroke a 4G63 because there is no shorter stroke crank readily available!
You CAN DEstroke a 4G64 with a 4G63 crank! Do the math again....
4G64 DEstroker:
An 86.5mm piston has a cross sectional area of ~5877mm^2, times 4 pistons is ~23508mm^2, times a SHORTER 88mm stroke is ~2068704mm^3 which is ~2.06L or 2.1L, incredible!!!
Why do this?? The destroker is essentially a 4G63 with a taller deck height (read: londer rods decrease rod angle creating less cylinder side loads = higher RPM tolerance) and punched out 1.5mm for a bit more displacement.
Geometry is fun!!!
- Steve
I Learn something NEW everyday!!!! Good Info.
Old Apr 12, 2006 | 01:52 PM
  #57
SuperHatch's Avatar
Question to some of the old timers out there....
Would the 4G61t crank interchange like the 63 and 64 cranks? It's a 75.5mm stroke btw....
4G64 "Double-D"stroker:
An 86.5mm piston has a cross sectional area of ~5877mm^2, times 4 pistons is ~23508mm^2, times an EVEN SHORTER 75.5mm stroke is ~1774854mm^3 which is ~1.77L or 1.8L...
Old Apr 12, 2006 | 02:09 PM
  #58
NDgsx's Avatar
It should, bearing part numbers are the same, but it's a six bolt crank, not seven. You couldn't use a evo block. It would mean setting up a cam angle sensor off a 1G dsm OR machining a mount for the crank pickup. Also you would need a different flywheel.
Old Apr 12, 2006 | 02:13 PM
  #59
SuperHatch's Avatar
That was my fear.... at least I can keep it in mind for a sick 1G DSM race car motor that I'll never build....
Old Apr 12, 2006 | 02:56 PM
  #60
sonicnofadz's Avatar
Wait a second. Am I missing something here? Are you guys talking about swapping in a 4g64 block into an Evo? Will an Evo head actually fit on this type of block, or will a dsm head have to be mounted? I am very confused...
