Low oil pressure on Defi BF
Old Apr 17, 2006 | 02:56 PM
Brembo350z's Avatar
Like the title says, I have a really low oil pressure reading on my defi BF gauge. I have the sensor mounted in the head where many others from this board have mounted it. So now for the issue, it reads as low as 1 or 0 at idle after driving for 20-30 minutes. The stock oil pressure warning light has never indicated a problem with low oil pressure. As rpm increases, oil pressure increases. So i find it hard to believe I have a bad oil pump.
My car currently has 15,400 miles on the ODO. Is it possible the sending unit for the defi gauge is causing the problem? Any test I could do to find the source of the problem would be of great help!
John
Old Apr 17, 2006 | 03:17 PM
kimletrim's Avatar
Registered User
Try mounting the sensor on plug directly above the oil pan. That location never gave me any problems.
Old Apr 17, 2006 | 03:37 PM
Brembo350z's Avatar
Thanks for the advice! I actually just got the adapter today, so that is what i'll try next!
Old Apr 17, 2006 | 04:05 PM
scott88vr6's Avatar
I have mine in the head, and it does the same thing, reads 0 and idle.
Old Apr 17, 2006 | 04:23 PM
Brembo350z's Avatar
Doesn't that get annoying when the warning signal keeps beeping? I just need to get the bolt that goes into the head because i lost it. If anyone knows the part # for this I need it!
Old Apr 17, 2006 | 05:53 PM
scott88vr6's Avatar
I have the D-gauge, no warning, but the same sensor
Old Apr 17, 2006 | 06:39 PM
EvilBlueEvo8's Avatar
John
My Stewart Warner does the same thing (well its in psi and not bar). Only difference is I have the pressure sender mounted in the blank spot in the oil galley near the oil filter already.
Old Apr 17, 2006 | 07:23 PM
dubbleugly01's Avatar
the head is not a good place to tap. There have been threads saying it's a good source, but it's not. Best place is by the oil filter. I made the same mistake, and then swapped to a plug by the oil filter, and all is ok now, and within the factory specs.
Old Apr 17, 2006 | 08:18 PM
sllt1776's Avatar
mine reads abou 1 at idle after warmup. not sure where it is mounted, i think near the filter.
Old Apr 18, 2006 | 03:20 PM
Brembo350z's Avatar
Ok, i have the adapter, but I lost the nut that goes in the head... I need to find the part #.
Simmons
Oct 24, 2013 01:08 PM
SuperchargedGTZ
Jul 7, 2007 07:16 PM
steve814
Feb 24, 2007 10:04 AM
nrcooled
Feb 11, 2007 12:45 PM
dreamevo
Sep 20, 2006 06:50 AM
