Weird problem when raining...??
Old Apr 18, 2006 | 09:41 PM
Bdub25's Avatar
Alright, Yes i have searched, so if you cant help, dont read this thread. My car seems to have a really weird problem, It only happens when it is raining out. It seems like the car boggs down when i am going at about 2-3000 RPM's when i start off driving but once i get driving for about 30 seconds it goes away. I removed my splash guard and i have a full tb exhaust. Is there a chance that something could be getting wet and messing up or something? It sounds almost like there is something rubbing the tire but i am 100% sure there's nothing hitting the tire. Sounds like a grinding sounds right under my transmission/middle of the engine bay. But my tranny is fine. Only happens when it rains too!! Please help!!!
Old Apr 18, 2006 | 09:42 PM
Bdub25's Avatar
Oh yea, it's a GSR evo 8, about 39k miles, and i dont really think any of my mods have to do with it.
Old Apr 18, 2006 | 09:57 PM
Ultimate CC's Avatar
this is a problem with your dp rubbing most likely, i remember reading this somewhere, I will try and find the thread....
Old Nov 29, 2006 | 02:56 PM
FerdEVO03's Avatar
Man, I have been having this same exact problem only when it rains. It almost seems like i have a hole in my intercooler and somehow its sucking in water. The car sounds like a WRX during acceleration. The car definately feels boggy and when i hit small puddles on the right side of the car I hear this weird knocking sound but, then goes away when I let go the pedal for a few seconds. Again, this only happens when it rains.
Old Nov 29, 2006 | 03:26 PM
hopper's Avatar
Do you have an open filter element?? Maybe your Mass air sensor is getting a little wet
Old Nov 29, 2006 | 03:38 PM
EVO8904's Avatar
The only time my car feels like it is bogged down is when I first crank it up in the morning. I thik that is normal though, it feels like a WRX KILLER after it warms up though, HEHEHE. I have a HKS intake and TBE and afew more mods. My splash guard is removed too. If I was having that problem I would take it to Mitsubishi and have it checked out.
Old Nov 29, 2006 | 03:42 PM
sonicnofadz's Avatar
Check to see if your air filter is getting wet. Also check for boost leaks.
Old Nov 30, 2006 | 04:30 AM
FerdEVO03's Avatar
Im running the stock intake box with a K&N panel filter and I have all my splash guards on. I will check my MAF
Thanks guys for you inputs
Old Nov 30, 2006 | 08:45 AM
Do a boost leak test, if you have a boost/vacuum leak somewhere, it could be sucking in water and unmetered air. Also make sure that the box & intake tube & snorkle is on tight.
Old Nov 30, 2006 | 09:05 AM
Corey's Avatar
If your MAF is getting wet you'll know it. Your CEL will come on and your car will start bucking and will not drive right. How do I know this? I sprayed down in the hood vent on accident one night while spraying off my car and got my HKS filter wet. Not knowing this, I continued to drive home and I guess some water got sucked into the intake and got the MAF wet. That is when the car started to buck at low speed and rpm. It eventually stopped by the time I got home.
Old Mar 20, 2008 | 04:56 PM
YzBrad99's Avatar
I looked at everything my DP could possible touch, no rubbing anything....anymore ideas about the vibrations when it rains?
Old Mar 20, 2008 | 05:11 PM
Insanenoodle's Avatar
try giving your drive shaft a good shake and see if it rubs or hits your exhaust or underbody
JoeyBoy
15
Sep 5, 2015 03:41 PM
spooldursti
17
Apr 20, 2011 02:12 PM
Spish
Nov 30, 2008 12:23 PM
MTRJunior
May 11, 2008 10:29 PM
RoughedgesMR
18
Jul 6, 2006 05:35 AM
