2.1L from SBR arrived...Pics
Old Aug 12, 2006 | 01:21 PM
  #46
cpoevo's Avatar
The 2.1 is not new to the community. The old school DSM guys used the 2.1. It is simply a destroked 2.4 block. The advantage is you get your displacement from the bore size vice the stroke length. You ask why this is better? What limits the engine is with a longer stroke you are concerned about the piston travel in FPM, feet per minute. With the 2.1 the piston ahs a shorter stroke so your FPM is lower than the 2.0 and you can rev it a lot higher.
Old Aug 12, 2006 | 04:46 PM
  #47
althemean's Avatar
It is new to the EVO community. READ closer next time. You offer nothing. This has been beaten to death in many threads all over the place.
Old Aug 12, 2006 | 06:11 PM
  #48
*chris*'s Avatar
Originally Posted by althemean
stock....for now. I just heard some rumors of a new turbo that FP is working on....by the time this project pans out they might have a better bolt-on replacement who knows. If not, once the motor is broken in I may just go with the TME.
ahhh ...i was thinking of going this route but going with a bigger turbo.
Old Aug 12, 2006 | 06:19 PM
  #49
cpoevo's Avatar
Originally Posted by Rez90
here's a question. and i know everyeone is going to tell me to search.......but if someone would answer me i would greatly appreciate it.
Whats the reason for a 2.1? you know...vs say a built 2.0 or a 2.3.......
Sorry I was just answering this question. You need to relax. I answered someones question with the technical data put in laymen terms so he could understand it. Sorry I have nothing to offer to you. As for Rez I hope I answered your question.
Old Aug 12, 2006 | 07:43 PM
  #50
althemean's Avatar
Once again....not trying to offend. But that was covered on the very first page of this thread on posts 10 and 12. READ CLOSER or try reading the WHOLE thread first.
Old Aug 12, 2006 | 08:32 PM
  #51
20psi's Avatar
another question. My head took some damage on the #4 cylinder combustion chamber. One of the intake valves had the rocker arm come off the valve stem/spring. I have no idea how that happened. I was thinking that I should reman the head but the price is high. Is it necessary to replace the valve guides? Or should I just go with new springs (obviously for the JUN cams) with new valves and seals? I dont think the valve is bent or made any contact with the piston. Can I get away with just replaceing the moving parts (which I can do myself)
hello, trying to offer some advice. What do you mean that the combustion chamber is damaged??? It has been my experience in building dsm's that the reason the rocker popps off is because the valve collided with the piston, bending the valve and not letting it go back to the seated position. This causes the space between the cam and valve stem tip(the part that touches the rocker arm) to increase and then the rocker falls out of place.
Now with that being said, if the rocker just "fell off" there would be NO combustion chamber damage because the valve would just stay closed and it would still have the other intake valve to run(probably poorly, but still run).
So what you should do is look closely at the valves, piston, guides.....something is wrong.(bent valve, hung in guide)....in extreme cases I've seen a rod bearing have so much clearance that the piston hit the head, anyway it definately does not happen for no reason.
hope my 2cents helps
-mike
btw nice engine!
Old Aug 12, 2006 | 10:01 PM
  #52
althemean's Avatar
I cant for the life figure out how it happened. The damage I am refering to is minor nicks from the piston as it came apart. I havent had the time (nor the tooling) to disassemble the head yet (it is off the engine I need a valve spring compressor). As of now I do not know if the valve is bent or not. I think I posted pics of the everything in a thread I started when the engine blew back in April. Searching under my name should show that thread if you are really interested in seeing the pics. Unless the timing belt slipped a tooth..I dont see how the parts could have made contact as the engine let go at around 3500-4k RPM. My AFR gauge showed a lean condition (I suspect the fuel pump) right before this happened. The crown of the piston broke off on the intake side so maybe they did contact. It is so hard to tell.
Old Aug 13, 2006 | 01:25 AM
  #53
Erik@MIL.SPEC's Avatar
Originally Posted by kjewer1
This HAS to get the award for the most poorly constructed longest run-on sentence in the history of the English language.
I hear that sentence is built better than SBR engines, though.
Old Aug 13, 2006 | 04:28 PM
  #54
althemean's Avatar
based on what?
Old Aug 13, 2006 | 04:44 PM
  #55
PA-silver03evo's Avatar
I guess he thinks he can do a better job.
based on what?
Old Aug 13, 2006 | 04:51 PM
  #56
Sorry, I guess I shouldn't have been presumptive. Hope all goes well.
evo+supra
30
May 15, 2014 11:52 PM
SBR INC
May 3, 2007 03:59 PM
kf6ytc
19
Apr 19, 2007 03:37 PM
BMWE30
Mar 7, 2007 08:42 AM
SlowboyMR
79
Apr 1, 2005 04:44 PM
