Clutch restrictor removal on Evo 8
Old Sep 9, 2003 | 03:22 PM
  #61
nastea's Avatar
ok now it works from half way up there is no pressure its all free play now....
Old Jul 23, 2004 | 08:27 PM
  #62
ariemcd's Avatar
Thanks
I have just put my car back together and it grabs much betto.
Old Aug 12, 2004 | 10:31 AM
  #63
amigoni's Avatar
Ok changed my clutch at 21K with Exedy Hyper Single. Got mistu to install it but they obviously messed something up.
When I first got the car the clutch would engage About 1/4 up from floor. Then after half a day of driving it started engaging higher and higher. Now it's all the way up top. I mean last 1/10th up top. I tried to change the pedal adjustment but that only changes if up top is closer to the floor or not. Still doesn't solve my issue. I think I might have to bleed my clutch line. Forgot to say I had them install a SS clutch line. I dont think they bled the system properly.
Another symptom happens when I slowly and carefully disingage the clutch at start and leave the rpms around 1.5 k the clutch grinds quite a bit. It's not smooth but clunky.
Also i now have much lowder transmission noise on decel at 3K but I think that's normal.
What do you guys think? I don't want to take it back to mistu. They will just tell me that it's the aftermarket clutch fault. Do you think they could have miss installed it? or is that impossible.
Old Aug 13, 2004 | 06:22 AM
  #64
bbbwrx's Avatar
You may need an shorter slave cylinder rod. If I were you I would make a new thread about this so you can hear from people with experiance.
Old Apr 9, 2012 | 08:38 PM
  #65
ablan029's Avatar
bringing an old thread back to life...i just did this tonight in addition to replacing the upper clutch line with a braided SS one and you can immediately feel the difference. the clutch grabs like it should!! i should have done this a long time ago!!
Old Apr 3, 2013 | 05:23 AM
  #66
TurboM3's Avatar
Registered User
Originally Posted by Incognito
OK, I re-bled the clutch line, and it feels a lot better now. Grabs right in the middle. The dead feeling of the pedal is gone. Bled the clutch using a trick a friend taught me. Hook up a vacuum line from the nipple on the slave cylinder to a vacuum source on the intake manifold. With the car running, crack the bleeder open, and the fluid will get sucked through, bleeding the clutch line. Only bad thing is that the exhaust will smoke like crazy for a few minutes (from the brake fluid burning). Bleeding the clutch this way is quick, and guarentees no bubbles.
I know this is old....but LOLOLOL
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
asu11
Nov 15, 2016 04:44 PM
Canada_Comp
20
May 13, 2013 10:00 AM
Randal
Oct 23, 2012 07:53 PM
pocoRA
04-06 Lancer Ralliart How To Requests / Questions / Tips
60
Mar 2, 2012 09:00 AM
