500whp stock block club
Old Jun 22, 2008 | 10:53 AM
  #256
khara's Avatar
Originally Posted by platinumspecv
You know. I dont understand what this is for. Are you trying to prove that since you achieved such high numbers on a stock block - it is OK to drive around like that and say that ur block will be fine? Or are you proving that the power you are making is compromising the longevity of your engine? Tell us .. Yes making such power with such a great tune is possible, BUT you ARE going to put in a new motor. I bet at least 2 out of those 7 are going to have blown engines.
So saying that "Yea the motor is good for this 500whp daily driving" is not such a good thing to say because it wont last 100k miles.
Not even on a stock Mods and Turbo will put on "100K Miles"?!!!
The answer is Yes, You can have a +500whp and drive around, and can even have a road-trip
If you read before your post, you will see that a member mentioned that +500whp have lasted for 15,000 Miles.
and lets say you have a stroker motor with a 35R and pushing around 700whp, the motor will last almost the same.
One love and Congrats to all
Old Jun 22, 2008 | 11:46 AM
  #257
khara's Avatar
Originally Posted by Paul Nelson
1081whp! Stock crank and block
Hahahaaha
good one
Old Jun 22, 2008 | 04:02 PM
  #258
Colt4g63's Avatar
Im in... 03 VIII all factory stock internals/block 58K miles. Stock intake and throttle body, Jun 272s cams with supertech valve springs, stock head/no port work, 880cc injectors, 255 pump, AMS FMIC, AMS GT35RL kit, AMS turbo back exhaust, modified EVO 9 BOV .
This is with 110 sunoco fuel and stock ECU flashed with boost at 32psi.
Old Jun 22, 2008 | 09:25 PM
  #259
dxbevo9's Avatar
30Psi Here...Stock Block, Cosworth Head, Cosworht M3 Cams, HTA35R 93 oct and 30psi-= 24k miles (3k Miles at 500whp) and still going strong
Old Jun 23, 2008 | 11:07 AM
  #260
jessvolution mr's Avatar
stock ecu(flashed)
Originally Posted by E VOL IX
WELL ADD ME UP
never had a graph for my 537 dyno
car has a COMPLETELY stock motor..head...ecu
tuning just on a ecu flash car is a evo IX
AFI 35r...880 injectors...smc methanol...cosworth cams...
o and BTW this was done on a mustang dyno
it made 568.. dunno why the graph only says 566
bro, wanted to ask you about your ecu.
my tuner tell me, with reflash ecu, the max hp that can obtain out if it is about 400++hp.Because of the oem intake airflow sensor restrition..how did you do that to get 500++ hp?? i need your help!! thank..
my set up is quite similar to yours...
Old Jun 24, 2008 | 08:36 AM
  #261
intake flow sensor
anyone know??
ups!!
Old Jun 24, 2008 | 09:20 AM
  #262
codean's Avatar
do you think that upgraded rod bolts are worth doing on a stock block car?
Old Jun 24, 2008 | 11:18 AM
  #263
ImprezvSE's Avatar
No, if your going to go inside then just build it while your in there.
I have 5,800 miles on my car 4,500 have been at 500+whp and the only time it comes out of the garage is to play. 30lbs all day and the car is going strong.
Old Jun 24, 2008 | 11:20 AM
  #264
EE's Avatar
EE
how is this turbo giving 450 pounds of torque at 5000 rpm??
even the HTA35 can't do it on a 2.0L engine!
Old Jun 24, 2008 | 11:43 AM
  #265
4kinboost's Avatar
Fire your tuner.
Old Jun 24, 2008 | 08:37 PM
  #266
4kinboost's Avatar
Add me to the list.. 506awhp/424tq. Stock top and bottom. Shell 93.
35r, cosy cams,and aem ems.
Old Jun 24, 2008 | 09:08 PM
  #267
BigBadQuattro's Avatar
congrats on making the 500hp stock block list...
Old Jun 25, 2008 | 04:35 AM
  #268
intake sensor
Fire your tuner.
fired!!!lol
so bro, do you mean you still on the oem flow sensor?the one in between the air filter and piping to turbo..
understand that if you at using aem ecu, the sensor should had removed,so no more restristion problem..
pls help!
Old Jun 25, 2008 | 04:40 AM
  #269
E VOL IX's Avatar
He sucks then...
35r .63 a/r
cosi cams
smc meth
intercooler
regular list
stock head
stock block
stock IM
stock TB
Stock Maf
I jsut made 530whp this past weekend at a dyno day with bad plugs and the ignition breaking up like crazy with a leak in the throttle body... so i had a boost leak and meth coming out of it.
tho some cars around here we have built just do pop 500... my car is kind of a freak
i have already made 580 before just pouring race gas in.. never tuned for it.. im sure she could break 600... as far as i know it is the highest hp stock block IX in the country
Old Jun 25, 2008 | 07:01 AM
  #270
gamebred26's Avatar
Nice job Erkel...you going to post the dyno sheet?
My car is still not done. I called you like 90 times!!
