Help: Sticking clutch (twin disk) at low rpms
Old Aug 21, 2006, 06:29 PM
TonyG's Avatar
Help: Sticking clutch (Exedy twin HD) at low rpms
I've had the Exedy Twin HD for 4000 miles, with 4 dragrstrip launches and two street launches. At first, driveability was flawless, but now, I'm starting to experience something strange.
Sometimes during normal stop/go driving (not racing), when I press in the clutch in to upshift, I can't get out of the gear that I'm in, i.e., I'm locked in. This usually happens right after I decelerate while in gear.
When this happens, it feels like there is still a load on the engine, even though the clutch is pressed in...I think the clutch may be sticking to the flywheel. I can force it out, but this feels almost like shifting with the clutch engaged. If I wait for a few seconds, or blip the throttle (while clutch pressed in), it comes right out of gear and the rpms drop.
I've learned to avoid the problem by giving the engine a slight rev during every shift (push in clutch, rev, then shift).
The strange thing is that shifting at high-rpms or shifting aggressively is no problem -very smooth. I only have this "sticking problem" when shifing at low rpms while coasting in traffic.
I tried two things so far:
(1) adjusting the clutch pedal to grab at a higher position,
(2) bleeding slave cylinder
neither one helped.
Any ideas?
Old Aug 28, 2006, 09:52 PM
TonyG's Avatar
any ideas?
Old Aug 28, 2006, 10:58 PM
Zeus's Avatar
Disc/discs may have been warped upon install, and the splines on the input shaft may not have been properly lubed. Generally you are not going to get it fixed without pulling it...
Old Aug 29, 2006, 08:10 AM
TonyG's Avatar
Thanks Zeus,
Someone mentioned in another post that upgrading the cylinder rod will help, but it hasn't been elaborated on. Ever hear about this?
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
svt_lightning01
Aug 10, 2011 10:07 PM
guitardave24
38
Jul 26, 2010 03:22 PM
72Tornado
Jun 22, 2007 11:00 AM
xenonk
Driving Techniques
11
Feb 26, 2007 07:37 AM
Quick Reply: Help: Sticking clutch (twin disk) at low rpms
