Serious Problem,,,please help
Old Sep 7, 2006 | 09:40 AM
  #31
hotrod2448's Avatar
Originally Posted by first5.0
i'm not sure where the starter is on the evo's but on my mustang the starter would get very hot due to being close to the aftermarket exhaust. i replaced it with a high-torque mini starter and it's been a lot better.
Read what the guy wrote.
The car is running fine, once it gets hot it mysteriously shuts off, turns over fine but, doesn't start until the engine cools off.
I have never heard of a starter doing any of that. If he started the car, drove to where he was going, got the car up to temp, turned the car off, then tried to restart it and, it wouldn't turn over or struggled to it would probably be the starter.
I would venture to say it is fuel related as several others have.
Old Sep 7, 2006 | 09:53 AM
  #32
Rob W.'s Avatar
Fuel fuel fuel. Ignore the comments about starter stuff.. people aren't paying attention to you.
Either your pump is bad (or the connection), your fuel pump relay is bad, your FPR is bad, or your ECUTEK flash is crap.
Personally, I'd start with the easiest stuff first: 1.) replace the pump relay 2.) swap back to your stock pump 3.) Reflash back to stock 4.) Replace FP regulator
Good luck!
Old Sep 7, 2006 | 10:05 AM
  #33
feautoevo's Avatar
Just saw this thread, I'm thinking it's your problem, same car similar mods and all al did was change to a walbro and poof everything was fine: https://www.evolutionm.net/forums/sh...hreadid=221963
Old Sep 7, 2006 | 10:07 AM
  #34
whitey4d's Avatar
Hw said he already has a walbro if any body read the whole post before chiming in. It difinitely sounds fuel related like the FP relay is over heating and sticking there. I would try a relay first then report back.
Old Sep 7, 2006 | 01:02 PM
  #35
nothere's Avatar
what type of driving are you doing when the car shuts down? hard accelerations or just cruising?
Old Sep 7, 2006 | 04:17 PM
  #36
2theMAX's Avatar
Yes, but the Walbro pumps have known to go out from time to time.
Old Sep 7, 2006 | 06:54 PM
  #37
caligula's Avatar
it could be you crank sensor as well. it could be many thing's i wish i was there to give you a hand and test thing's out.
jerrymldz
Jun 16, 2017 02:40 PM
LancerMM13
Lancer Aftermarket Forced Induction Tech
80
Feb 3, 2016 06:51 PM
Babs
Jul 11, 2013 06:42 PM
yikez
Sep 6, 2008 03:44 PM
nastea
26
Oct 29, 2004 11:52 AM
