ALKY Injection Gone Wrong........ WAY wrong.....
Old Nov 8, 2006 | 08:49 PM
  #61
C6C6CH3vo's Avatar
Spooled you, whats your plan for rebuild?
I think you have the only 04 in the hall of fame. Sorry some negligent mechanic killed your engine
Old Nov 8, 2006 | 11:25 PM
  #62
MR. Birdie's Avatar
Isn't SMC suppose to release their new version kit with the failsafe?
Old Nov 8, 2006 | 11:32 PM
  #63
TTP Engineering's Avatar
There is no bulletproof meth injection system available. SMC's alleged "failsafe" would only cover about 10% of the causes of system failure. It helps, but is not a system that will let you sleep well at night.
Old Nov 10, 2006 | 07:04 AM
  #64
Spooldyou's Avatar
Ahhhaaaaa... True... but this isnt a blown motor. Just human Error!
Im planning on a built 2.0 With a 35r. Build Head, All new everything i have a Thread Running https://www.evolutionm.net/forums/sh...15#post3652415
Check it out Good luck guys!
Old Nov 10, 2006 | 04:54 PM
  #65
dean evo9's Avatar
I agree after a lot of reserch i choose cooling mist that cant happen with there nozzles , a 1/8 inch pipe nipple must be welded to the upic than the nozzle threads in , but thats the risks we take , ,sorry to see that i feel for you
Old Nov 10, 2006 | 07:18 PM
  #66
SophieSleeps's Avatar
If you're really concerned about kits, build your own.
None of this plastic tubing junk.
Use a quality nozzle, a 1/16 NPT threaded nozzle and weld-in bung.
Stainless lines and a quality pump.
Purchase a controller, water level sensor etc.
If you price that stuff out, you won't be much more than $300.
SoundBoy4
Jun 27, 2009 04:58 PM
Spooldyou
46
Mar 10, 2007 01:37 PM
MTRJunior
Feb 27, 2007 09:16 PM
