Odd Idle issue
Old Nov 4, 2006 | 04:31 PM
joon's Avatar
Odd Idle issue
I searched the archives for any input, but i got none.
When i turn the A/c on, and im at a stop light, the car turns off. I can see my idle go from 800/900 drop to like 700-600. tHIS also happens when i turn my fog lights on. anyone have any idea?
i just got my transfer case, my car had been sitting for over 6 months, but shes running now
anyways, does anyone have any ideA?
Old Nov 4, 2006 | 04:35 PM
Cirrusly Evolvd's Avatar
What type of BOV do you have? And do you have cams?
Old Nov 4, 2006 | 07:54 PM
joon's Avatar
i have an HKS bov, dont know the model. No cams.
Old Nov 4, 2006 | 08:00 PM
ak47po's Avatar
Does it recirculate.
Old Nov 4, 2006 | 08:33 PM
joon's Avatar
im sorry, i dont know what you mean. The bov works perfect.
Old Nov 4, 2006 | 08:35 PM
ak47po's Avatar
Does it vent to the atmosphere or back into the intake.
Old Nov 4, 2006 | 08:37 PM
Dnealy's Avatar
A recirculating BOV would let the air return back into the intake tube. The Hks has a special part need to do this, did you put it on your self or did you buy the car with it one there? Does the BOV have a tube that runs back into the intake pipe?
If not then 9.9 times out of ten we just narrowed the problem down.
Old Nov 4, 2006 | 08:52 PM
joon's Avatar
i bought it as it is. my car was sitting for six months as i was awaiting my Tcase. it was working perfectly (the car) before i blew my t case.
This evo is making me go crazy honestly. I still love it though.
Old Nov 5, 2006 | 06:52 PM
joon's Avatar
i just got code p0300. Oh, mAN, am i in trouble?
What cAN IT be? it has new plugs with about 300 miles or less on them. can it be the coil pack? my evo has 37000 miles. 2003 lancer evo.
Old Nov 6, 2006 | 12:51 PM
I wouldn't worry too much bout P0300 as long as your plugs are good. I doubt there's many owners who HAVEN'T gotten that code before.
Old Nov 6, 2006 | 01:02 PM
Smike's Avatar
Search VTA. Which from the sounds of it, is what you are running. The AC runs off belts, when the compressor turns on it will "take" some power from the motor.
I suggest getting rid of that BOV and getting one that is recir (IX DV, Forge DV, or APS BOV).
Old Nov 6, 2006 | 10:03 PM
vassago's Avatar
vta isn't that bad...... i have my ssqv vta right now..... it ran like crap until i reset my ecu.... now it's fine....
Old Nov 7, 2006 | 05:50 AM
Smike's Avatar
Yes it is. Search. MAF measures air, when you dump that air out in VTA it will cause the ECU to run rich because it thinks the air is there, but isnt. This causes poor driveability, and stalling at stops.
Our DVs also open slightly at idle to allow air back into the intake. In VTA that air is dumped out and this will also cause stalling at idle.
Unless you go to MAP you have to recir for MAF - period.
https://www.evolutionm.net/forums/sh...&highlight=VTA
https://www.evolutionm.net/forums/sh...9&postcount=15
https://www.evolutionm.net/forums/sh...3&postcount=47
https://www.evolutionm.net/forums/sh...9&postcount=17
Old Nov 7, 2006 | 06:03 AM
evo-mike's Avatar
1. get a new BOV/DV. (recirculating)
2. check vacuum lines
Old Nov 7, 2006 | 06:47 AM
Zeus's Avatar
Use a diverter valve that recirculates, and not a BOV or live with the fact that you will ALWAYS have gremlins.
You can still get that RICE BOY sound will a Forge diverter valve and a Buschur cone filter on the OE intake tube. Matter of fact, it can be loud as hell.
Check all your vac lines... also, are you tuned for all your mods?
EvoDan2004
Oct 14, 2016 08:30 PM
J8dailo
Feb 1, 2012 08:53 PM
Talon_66
24
Jun 10, 2008 04:40 PM
72Tornado
Feb 6, 2008 06:40 PM
Drewbell
Lancer Engine Management / Tuning Forums
31
Mar 11, 2007 03:56 PM
