View Poll Results: Which ACT is better
ACT HDSS kit
14
45.16%
ACT XTSS kit
17
54.84%
Voters: 31. You may not vote on this poll
ACT HDSS vs XTSS
Old Nov 15, 2006 | 01:52 AM
shinynsilver's Avatar
ACT HDSS vs XTSS
Wot are the differences between price and FtLb limit on these to clutch its, is the HDSS a smoother enage then the XTSS, any pro & cons on them both. PLEASE HELP
Old Nov 15, 2006 | 02:35 AM
riceball777's Avatar
hdss is rated at 497 tq and the xtss is rated at 567 tq
so the extream pressure plate will hole a little more power and the zlutch pedle will be harder with the xtream pressure plate
only the pressure plate is different the clutch disk is still the same
Old Nov 15, 2006 | 03:10 AM
ONRAILS's Avatar
the xtss is rated at 636
Old Nov 15, 2006 | 03:47 AM
Would the enagement of the clutch be the same, even if the pedle is stiffer, ie would it grab and judder wen engaed like paddle clutch would
Old Nov 15, 2006 | 10:55 AM
t51splbb's Avatar
The answer to the above is yes,the engagement characteristics are going to be the same,since the only part changed is the pressure plate. A organic disc by design is not going to have the same engagement as a puck style/padle style. Not sure where some of the torque numbers posted are coming from, but from ACT the HDSS is rated at 508 lb ft and the XTSS at 567 lb ft both measured at the crank.
Old Nov 15, 2006 | 06:43 PM
highpsievo8's Avatar
i just put the hdss in 150 miles ago. so far so good
Old Nov 15, 2006 | 06:46 PM
lcakes05's Avatar
niether
Old Nov 16, 2006 | 06:10 AM
600+hp's Avatar
I got the XTSS since my car was making 460/440 whp, let me just tell you the heavy pedal feel get really old real quick in the traffic after a long day at work. It's not such a big deal when you first get started in the morning 'cause you've just had a full night rest.
My car is a daily driver, I logged in about 15K in 6mos or so.
Old Nov 16, 2006 | 06:28 AM
dennyt4's Avatar
I had the XTSS in my previous Evo...I loved it. A little heavier than stock, but not bad at all and I sit in a lot of traffic coming home. Of course, I grew up driving a 68 GTO w/ a REALLY heavy clutch!
Good luck...and MAKE SURE they use Diaqueen in the TC after the install!! LOL
Old Nov 16, 2006 | 07:05 AM
Spooldyou's Avatar
depending on your mods list, I would say that the hdss is more than enough for most. I think that you should be fine, i ran mine in my car for almost 20k with over 100 launches/ or more with no issues. Just some minor Adjustment stuff but other than that.
Old Apr 16, 2007 | 12:02 PM
High_PSI's Avatar
That is with the 6-PUK disk. With the Street disk it is lower but still more then most people would need. I had the HDSS in my 2003 VIII and if anything it felt light to me and worked VERY well, no lock out at all. Held everything I could throw at it with ease.
Old Apr 16, 2007 | 01:17 PM
kouzman's Avatar
that's good to hear. I ordered the XTSS for my car and a daily driver clutch with quite a holding capacity is what i wanted...
I see that the XTSS can cover all my needs for now...
good good...
tenney
Jun 29, 2016 09:50 AM
DarkEvo
Mar 29, 2013 07:14 AM
tehSteve
Jul 31, 2011 10:56 PM
m4tt VIII
12
Apr 5, 2010 11:16 PM
riceball777
63
Apr 26, 2008 10:26 PM
