Anyone using the Saiken Michi co. DC3 Catch Can?
I am using it, and like it a lot. I got "creative" using both supplied mounts to get it into the location I wanted, and it works great. Just emptied it today. Had a few ounces in the PCV side tank and nothing in the vent side tank.
Keith
Keith
so is that the official place that evom members are mounting there DC3? i had also found that website in which was my reason to purchase one. just seeing if anyone had done it differently.
https://www.evolutionm.net/forums/sh...&postcount=137
https://www.evolutionm.net/forums/sh...&postcount=146
https://www.evolutionm.net/forums/sh...&postcount=164
https://www.evolutionm.net/forums/sh...d.php?t=209109
http://www.saikoumichi.com/DC3_page.htm
If you get the individual DC3 cans there is room to mount one on the firewall behind the pcv with a existing oem bolt that holds a square looking black relay.
Thats where I mounted the can with the provided bracket and it is level with the valve cover. The line routing from pcv-can-intake is shorter too.
https://www.evolutionm.net/forums/at...5&d=1150767190
https://www.evolutionm.net/forums/at...4&d=1150767185
I have mine installed right next to master cylinder. It is the dual can setup. I had to tap a small hole to do this into the firewall but I am not too worried about it. Its a tight fit but when I was all done I still had around 4 feet of line left of the 10 feet that was included. I will try to post a picture.
