fpevo green dyno numbers
Old Apr 16, 2007 | 07:31 PM
  #646
dadriva's Avatar
OK just go the car home and WOW!
Boost response is excellent. Drivability is great.
Boost is set to 31psi on pump and tapers to ~27psi at redline.
I was mistaken abou the pump gas numbers though...
pump + alky = 409whp, 423tq
C16 = 430whp, 453tq.
I've only driven it on pump + alky and it is making 2hp less than the last setup on C16. then 411hp c16 vs. now 94+alky 409hp.
Old Apr 16, 2007 | 07:39 PM
  #647
mudduck's Avatar
^^^ Great to hear!!!
Is it just me, or is your car with FP Evo Green putting down around 515/545 (Dynojet) on C16?
I wonder if you'll be able to match your old setup's 124mph trap on PUMP gas!!!
Old Apr 16, 2007 | 08:06 PM
  #648
yellowEVO21's Avatar
a 20% conversion might be a tad high....even at 12%, ~482 isn't bad at all...
Old Apr 16, 2007 | 08:07 PM
  #649
Blue Evo 8's Avatar
Yeah thats what buddy of mine told me today as well.....
Old Apr 16, 2007 | 08:12 PM
  #650
mudduck's Avatar
yeah, and don't forget (using 12% now) the 500+ wtq!!! + some nice spool-up = one NASTY daily driver!
Old Apr 16, 2007 | 08:47 PM
  #651
High_PSI's Avatar
trap speeds tell all
Old Apr 16, 2007 | 08:50 PM
  #652
Blue Evo 8's Avatar
Originally Posted by High_PSI
trap speeds tall all
Yep, thats true....
Old Apr 17, 2007 | 08:36 PM
  #653
hopper's Avatar
Is there any surging with this turbo? I had a sleeper 16g on my talon, pretty much a 20g wheel in a 16g housing and it surged. thanks for input!!
Old Apr 24, 2007 | 03:35 AM
  #654
ill-luzion's Avatar
hey could you pm me with your complete setup.thanks
Old Apr 26, 2007 | 07:34 PM
  #655
Blue Evo 8's Avatar
I found this from another post:
Originally Posted by davidbuschur
Mr.Birdie, hard to tell on the internet but I senses some sarcasm. What I said about the tune on 91 not being a concern is not exactly what I meant. The car is completely tuned to run 91 octane, what I didn't do was try to run 25 psi on it and make absolutely as much power as possible on 91. He was not concerned with making power on 91 octane as a matter of fact he didn't even want a tune for it as the car will only see C16. I tuned the car on the 91 that was in it so he could have a map in an emergency if he had to put 91 octane in the car to get home from somewhere.
Hopefully that is more clear now. The 420 whp it made at low boost on 91 octane is atleast 450'ish on a Dynojet, not bad numbers.
Old Apr 26, 2007 | 07:40 PM
  #656
mudduck's Avatar
^^^ That'd only be like a 7.5% correction from the BR Mustang Dyno to a Dynojet...
Did BR recently change their calibrations from heartbreaker dyno to a normal-reading Mustang dyno???
Old Apr 26, 2007 | 07:41 PM
  #657
Blue Evo 8's Avatar
Thats a good question....
Old Apr 26, 2007 | 07:43 PM
  #658
dadriva's Avatar
As far as I know it is still the ultimate Evo fanboy ego buster.
I also thought the numbers would be much higher on a DJ.
Maybe some guys that have dyno'd on a DynoJet and trapped in the 124 mph range can chime in.
Old Apr 26, 2007 | 07:46 PM
  #659
mudduck's Avatar
In this business, you can't really blame them...
This would make some of the more recent Green turbo #'s a little more believable; of course now it looks like we have to rely on trap speeds more than ever...
Old Apr 26, 2007 | 07:48 PM
  #660
dadriva's Avatar
Maybe you misunderstood my post....As far as I know it is still calibrated to read low just like it always has.
