fpevo green dyno numbers
Old May 15, 2007 | 09:45 AM
  #691
Soon2BEVO's Avatar
Snow Performance 2D Kit and a Tial BOV
Old May 15, 2007 | 09:50 AM
  #692
mudduck's Avatar
How's your drivability with the TiAl on stock ECU?
Old May 15, 2007 | 10:33 AM
  #693
High_PSI's Avatar
Yeah that Tial holds serious boost. I was wondering the same Tom, does it open under light boost applications or does it give compresser surge from not being able to open under low boost?
Also what BOV did you run before the TIAL?
Old May 15, 2007 | 10:45 AM
  #694
Soon2BEVO's Avatar
I ran a stock EVO9 BOV before. The Tial is tricky. If youre going to run it without EMS you must use the stiffest spring. Now with that said, you are going to experience compressor surge more easily, however its not bad. It is BAD on the highway though. The parkway is not fun to drive on simply because you have to learn to hold your speed steady. If you build 5psi let says you have to let off the gas immediately to let it release the air or the car will buck. I dont drive on the highway at all anymore (except when I chased the Lambo and Z06 on there )
I honestly dont reccomend it unless you have EMS. I got it because it sounds downright nasty and it holds the boost. To me, getting rid of it at this point since I already have it would be more expensive and a pain in the ***. If I did it all over again, Id get a Forge or something similar that had better driveability, reciruculated and that could hold 30psi of boost.
Old May 15, 2007 | 12:24 PM
  #695
High_PSI's Avatar
Great input. I obviously have the IX BOV, you think it'll hold 24PSI without leaking? what is it rated too?
Old May 15, 2007 | 12:38 PM
  #696
Soon2BEVO's Avatar
It will hold 24psi no problem. I tested mine up to 26psi then it started to leak a little.
Old May 15, 2007 | 02:02 PM
  #697
dadriva's Avatar
A valve that will hold the boost is great and all. But a valve that holds high levels of boost and is driveable is a rare find.
I run the Forge recirculated (like Tom mentioned earlier) and am very happy with it's boost holding and am especially happy with its driveability.
Old May 15, 2007 | 05:25 PM
  #698
mudduck's Avatar
Anyone know if I could run the ^^^ Forge recirculated while still on stock ECU with good results?
Old May 15, 2007 | 05:38 PM
  #699
jhanksevo's Avatar
Forge RS or Forge DV dadriva?
Old May 15, 2007 | 05:48 PM
  #700
dadriva's Avatar
The stock ECU most definitely prefers recirc setups. You should be just fine on the stock ECU. I thought this was pretty common knowledge but am more than happy to let you know.
I run the Forge RS recirc and love it.
Old May 15, 2007 | 05:51 PM
  #701
Exciting News's Avatar
Forge RS? Absolutely. Plenty of people (myself included) run it on the stock ECU. It's a quality piece. Anodized black is trick and definitely the one to get.
Old May 15, 2007 | 05:52 PM
  #702
Mellon Racing's Avatar
anyone rocking the green on the stock 8 bov and having success?
Old May 15, 2007 | 05:58 PM
  #703
dadriva's Avatar
^^ Sure, it's possible, but you won't see maximum gains from it as I would surmise that it would be the weakest link in the equation. I'd expect the stock 8 bov to start leaking around 25psi.
Old May 16, 2007 | 12:54 AM
  #704
Erik@MIL.SPEC's Avatar
Are you talking about the stock plastic BOV? I have seen stories of people saying it holds boost to 21psi and others saying it started leaking around 8-10psi.
The Forge RS valve is a thing of beauty. Mine is going on when I get the green installed.
Old May 16, 2007 | 05:09 AM
  #705
matt55's Avatar
My 2c.
Ive bench tested the 2003 plastic bov and it leaks @12psi
JDM/MR/EVOIX bov leaks @24-25psi
Forge RS great psi holding , but i had bucking and chuffing so iam back to the EvoIX bov .
Side note Forge customer service is great !!
