fpevo green dyno numbers
Boost taper is a ****!!!!
Why not C-16....well i have a pay at the pump 111oct here in Vista...and its only $6.85 a gallon to $9-10 a gallon to make only 10-20 more whp on C-16...
Yours did very well, Manny; But you also had 2 very good friends and experienced tuners work on your set-up to make sure the results were nothing but the best,
Not everyone has this type of support, that is why the correct parts and tune must be used, or the numbers will never be there, on any type of fuel.
I live in California....open intake equals an almost automatic SMOG ticket/visit to the ref and going back to stock in the process...my engine bay, other than the BOV, looks stock and a fix it ticket for an exhaust is easier to fix than having to go back to stock on it all...something else has to give....maybe an 18lbs waste gate actuator...anybosy have boost logs with the 18lbs wastegate @ 30+ pounds?
34psi, Hit max load at ~3850. Flashed stock ecu, BR deluxe fmic, 680 injectors, stock intake manifold, stock throttle body, stock IX intake cam with 272 hks exhaust cam, 3" br tb exhaust with 20GLT and stock exhaust manifold. Forge RS diverter and stock IX actuator (may be changed soon).
