fpevo green dyno numbers
Since this thread has gone a bit off course and we're discussing BOV's and DV's. Maybe someone can enlighten me. Since installing my Green, I get this air escaping, hissing type sound when I let off the throttle driving under light load conditions. I don't know if it is my IX DV fluttering or if it's compressor surge. How can you distinguish these two sounds?
EDIT: Maybe my car always had this sound since switching to the Green, but I never noticed it with te stock airbox. I noticed it for the first time after installing an open air, pod style, foam air filter.
Did you try adjusting it? My car started suffering from surging after I installed the intake and I loosened the Forge RS until it calmed down.
.But it did sound cooler the the stock IX bov
right, I know it's not ideal, I'm just wondering if anyone has done a project low buck 20G LT/Green route and had success with it.
Its definitely not ideal but its also pretty senseless. You can get a metal EVO IX BOV for around a hundred bucks and even cheaper used. No matter how budget you are, you should have at a minimum, an EVO IX metal BOV.
I gotcha. It's just that the turbo is going to cost a minimum of $1000 so cheaping out on a $80-100 BOV doesnt make much sense.
I know this is still a little OT, but holding boost is a closely related subject...
Having had problems with all my DVs over time, I made a tester out of random parts you can find at any HW store.
Here is a pic, with a Greddy RS temp installed for the example:
I just plug it into my air supply, and slowly turn up the regulator and watch the PSI guage.
Here is what I found:
My stock plastic DV - started leaking at <10psi
My crushed metal MR DV - started leaking at 20psi
The RS pictured - leaked almost immediately; it has a ripped diaphagm. so no surprise..
Note: by "leaking" I mean you could start to hear the air escape past the seat seal.
I am now waiting for my APS to arrive, and this is the first place it is getting installed, not the car...
Edit: fixed bov reference
Let's see. Stripped studs in the turbo I bought. Needed to get them extracted. And then I needed to get the threads re-tapped. And then I got a custom port job on my hotside. And then I sent my hotside to get coated and SwainTech is busy right now...so that was another 3 weeks. My hotside should get here by the end of this week...so in the next 3 weeks I will get everything installed
Finally.
