Atp Kit/pruven Dyno Results!!!!
Give me another good reason why the cheapest, most accessible turbokit wouldn't be used by more people?
This forum is filled with all kinds of people/owners can you give me a better guess as to why we havent seen them on here? The other one could be because the results were that dismal?
Scorke
Scorke
I don't get why your running only 25PSI with METH on a 35R (30R?) Either way 25 is way too low and recent studies have show a properly set up 35R can run 25PSI on pump alone. Why not run 30PSI?
The turbo's housing adapts to the stock manifold. The increase in back pressure causes heat to accumulate near the head. As the exhaust gases back up in the manifold they create contamination in the cylinder head This contamination reduces the knock threshold of the motor. You have to run less timing and less boost. That is why tubular headers that remove the gases away from the motor before they collect them can run more boost and timing on the same given fuel. if this were not the case, everyone would be running log or cast manifolds.
i have a tubular manifold first off. Full race
second off its a 3037s/3076r not a 35r. i didnt want to go above 27psi or 480whp which ever came fist due to the stock bottom end.
thridly, laggy? i hit full boost by 4600 or so. its not as laggy as it appears.
and as for u shark- u are a tool with too much money. take ur assinine comments elsewhere.
u know what scorke, no one can tell u otherwise. you are always right, always buy/make the right parts and rarely give anyone/anything else credit where its deserved. anytime u say anything to anyone on this forum, it has to be taking with a grain of salt because if not like exactly like yours, something is wrong and the product sucks.
It is impossible to make everything yourself (or at least it was for me haha). I give credit to anybody/everybody that puts together a well sorted car. There is nobody on this forum that has a setup exactly like mine, and I rarely bash vendors products, only a couple who seem to really suck.
Scorke
Pruven are awesome guys, have never done me or anyone i have sent there wrong. and in fact always give me awesome deals on parts and installs.
Thats just simply untrue.
Scorke
Scorke
i have read countless number of times u bashing or saying bad things about other top notch vendors, so i really dont know what to tell u. u and many others feel as though ATP is crap, well i disagree.
Deadbeat, there is no reason to make 27psi or 480whp your cutoff due to the stock bottom end. That's not even close to what it can handle safely. You say full boost by 4600, but peak torque isn't until 5100. What matters is what we see on the dynosheet, because that's our frame of reference.
Personally, everyone bashes the kit, but it's still making more power than most other evos in the area and on this board. Most people just have simple bolt ons and for the price/power output it justifies the cost.
OT - I'm a bodybuilder too =D hah.
