AMS TBE IX MR rubbing
Old Feb 25, 2007 | 05:15 PM
Mitsu3's Avatar
i have the ams tbe w/hfc and the downpipe rubs on the transmission sometimes and the back of the cat pipe touches a bolt for the heat shield. Does anyone elses do this. It doesnt do it all the time though. Should i just get some exhaust wrap to stop the noise from the rub??
Old Feb 25, 2007 | 07:00 PM
Mitsu3's Avatar
come on someone answer
Old Feb 25, 2007 | 07:27 PM
SlowCar's Avatar
call AMS?
Old Feb 25, 2007 | 07:28 PM
MREvo2k6's Avatar
I dont have the AMS tbe but I had the perrin tbe on my evo VIII and it fit fine and than i put it on my IX MR and it hit the tranny, Its no big deal i just beat it in with a hammer a little bit right at the spot it was hitting. Now its fine. good luck
Old Feb 25, 2007 | 07:33 PM
thatguy's Avatar
Just get a hammer and message it out of the way, no biggie, I removed mine.
Old Feb 25, 2007 | 07:35 PM
belizelittle39439's Avatar
I would say call AMS. This is probably an issue that only occurs every so often since you don't hear about it happening all the time.
Old Feb 26, 2007 | 08:19 AM
3000ways's Avatar
Get use to it, it's common when going to a 3 inch pipping. I mean it could be an install problem, but mine rubs and it's a little annoying, but not causing any damage.
Old Feb 26, 2007 | 08:32 AM
Curt@MrLed's Avatar
Former Vendor
mine wasnt made for acd, but i still have no rubbing.. just a couple precise whacks with the b.f.h..
Old Feb 26, 2007 | 08:45 AM
Bigl4201's Avatar
Get the kartboy exhaust hangars. trust me. it works, My Dc downpipe was rubbing until i changed out my ****ty stock exhaust hangars.
Old Feb 26, 2007 | 11:43 AM
AutoMotoSports's Avatar
if the downpipe is rubbing the trans you most like just need to realign the system.
You cant just bolt it all up and tighten it down, you should loosen it up and readjust it where you want it to line up.
if its a IX you are more then likely rubbing on the bolt for the driveshaft carrier bearing heat sheild. I removed the sheild on mine and bent the bolt out of the way. I have a resonated test pipe so I have even less clearance but after that I had no contact issues of any kind.
Eric
Old Feb 26, 2007 | 12:07 PM
the chosen one's Avatar
are u crazy??
racr00089
15
Aug 5, 2010 01:25 PM
mantosride
17
Oct 13, 2009 10:51 PM
Need4Spd
Automotosports - Illinois
Jul 8, 2009 09:27 AM
joseph k
Feb 7, 2009 07:24 AM
crow
Mar 10, 2006 06:19 PM
