real intercooler test on the way
Old Apr 20, 2007 | 08:22 AM
  #211
trinydex's Avatar
so then what are you basing your arguement off of? your superior intuition???
and yes i know that it's carbonated... guess what the fog is made of ad then explain why the fog (and what's made of) is there and how/why it happens.
then you'll get the idea
Old Apr 20, 2007 | 09:16 AM
  #212
4G63DSM's Avatar
superior intuition? no.
superior intellect?? yes!
i am pretty sure i know what i am talking about when it comes to thermodynamics...
nuclear reactor research site i work at in idaho, and the navy thinks i know this stuff pretty well......
what does the release of pressure in your soda pop bottle have to do with intercooler tests?? nothing? and swimming in a pool?? nothing!!!! get back on topic!
Old Apr 20, 2007 | 10:12 AM
  #213
trinydex's Avatar
no please explain why it happens... give me the thermodynamic process... and then you'll see my point. i'm done explaining things to you.
Old Apr 20, 2007 | 11:07 AM
  #214
94AWDcoupe's Avatar
Amazing that you are in the thermodynamics field. Your ignorance on the subject is not worth arguing with. This is my last attempt to explain it to you. If you dont get it this time you need to get it elsewhere.
The latent heat of evaporation we are discussing about applies to the outside of intercooler, not the inside. Yes there is a huge amount of flow of hot air through the inside This will always heat the core plain and simple. The point I was trying to make was the starting temerature of the core could be lower than ambient if moisture condensed on the exterior surface of the core. And then evaporated off the core to bring the core temp well below ambient. Then you only have to realize the amount of heat that goes through the core in first and second gear is not enough heat to bring core back to ambient. So the outlet temp at that point could be lower than ambient.
It would be dumb to argue moisture doesn't collect on an intercooler or that the temp of the aluminum doesnt absorb heat energy in the avaporation process. Why did mistubishi install water spray for the intercooler? Because they are stupid and dont understand thermodynamics?
So far your arguements contain no technical facts or knowledge that apply here. Stop giving us your resume and start giving some real science.
Old Apr 20, 2007 | 11:12 AM
  #215
Erik@MIL.SPEC's Avatar
Pwned
Old Apr 20, 2007 | 12:21 PM
  #216
money pit's Avatar
oh man, that pretty much sums it up for me.
Old Apr 20, 2007 | 12:50 PM
  #217
_ceteuro's Avatar
Will the water sprayer help with the aftermarket intercoolers?
Old Apr 20, 2007 | 12:57 PM
  #218
SlowCar's Avatar
why waste water spraying it on the outside of the IC - injected it into the intake tract for excellent in-cylinder cooling
Old Apr 20, 2007 | 01:25 PM
  #219
Don't make a linear conclusion.
Why not do both?
Old Apr 20, 2007 | 01:27 PM
  #220
_ceteuro's Avatar
Sorry I am a little new to this but how do you do that?
Old Apr 20, 2007 | 01:40 PM
  #221
evoteddy111's Avatar
i would sell each fmic before u tell everyone the results lol
Old Apr 20, 2007 | 01:48 PM
  #222
SlowCar's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=244100
Old Apr 20, 2007 | 03:08 PM
  #223
ant_turbo's Avatar
So the ebay intercooler is good or no good>>>
Old Apr 21, 2007 | 10:42 PM
  #224
wreckleford's Avatar
w/o waterspray how does moisture end up on the intercooler on a reguar sunny day?
Old Apr 21, 2007 | 10:59 PM
  #225
supersnow's Avatar
verdict on ebay intercooler?
