help !!!! pleas !!!!
Old Mar 19, 2007 | 12:45 AM
06redMR's Avatar
i was going pretty fast on the highway ... my car was put into neutral and then it stalled ... i turned it back on and now it doesnt boost at all ever and it only goes up to 1.5k max in each gear so about a 30mph top speed with my MR 6 spd ... then it starts bogging crazy hard if u get anywhere over 1.5k in any gear ... i need to get it fixed but i have no idea what it is ... anyone know about this or had an expereince .. im thinking maybe a self preserving system that the computer turns on if something happens ? i dont know but any help would be highly appreciated !!!
Old Mar 19, 2007 | 12:46 AM
ChuckP's Avatar
unbolt the negative terminal for a few minutes, then put it back on and start her up.
Old Mar 19, 2007 | 01:10 AM
SRT-TO-EVO's Avatar
Sounds like you may have blown an icp off. Check the pipe at throttle body, that's where they seem to blow off alot.
Old Mar 19, 2007 | 01:21 AM
tony_b's Avatar
yup, def blew off an intercooler pipe.
Old Mar 19, 2007 | 01:33 AM
ONRAILS's Avatar
sounds like the stock airbox got loose from all that air and the snorkle is hitting sucking up against your hood when you press the gas.
its a boost leak or what i said.
Old Mar 19, 2007 | 04:26 AM
Clutchdc5's Avatar
intercooler piping for sure...., check the bottum ones and the one by the intake manifold
Old Mar 19, 2007 | 04:38 AM
Anocaj's Avatar
yeah its the intercooler piping happened to me a few times till i make them really tight.
Old Mar 19, 2007 | 05:41 PM
WickedWhiteRS's Avatar
yup almost sit my pants the first time the intercooler piping blew off. Right after i installed hard pipes and boost controller. I have also had a friend that did have his snorkle lose a clips and cut boost at about 5000 rpms, took a solid week to figure out that it was that cause he had just doen work to it and thought it was something completely different
Old Mar 19, 2007 | 08:17 PM
mudduck's Avatar
Yeah, most common for me was where the UICP attaches to the throttle body. The first time it happened to me I almost crapped myself. But then I remember the same thing happening to my friend's S/C'd mustang (we actually had no tools at the time and tightened up his worm clamp with a penny we found on the side of the road... ).
Do yourself a favor - you don't need to go out and buy a dozen new T-bolt clamps unless you are boosting like 30psi - just tighten up those worm clamps good with a ratchet (not just a screwdriver... ) and you should be good to go...
I actually keep a mini ratchet with the exact socket used for the IC piping in my driver's door...
Old Mar 20, 2007 | 04:25 PM
alby988's Avatar
happend to me too, its the throttle body and uicp
silverevo05
Apr 19, 2017 08:40 PM
evoxboost
15
Apr 18, 2013 10:34 PM
bwanner
Jun 28, 2011 05:45 PM
BEISSEN
Jan 20, 2011 10:40 PM
Turbodemon
23
Dec 20, 2008 06:54 PM
