Datalogged Stock EVO With&without Spray
Old Jun 9, 2003 | 10:39 PM
EVOLUTIONIZE's Avatar
This was done at 10pm today, 79f temp outside. using 93 Octane, car is completely stock with 1050 miles. OBDII pocketlogger used.
Run#1
No Spray
3rd gear
RPM Timing Deg O2's
4757 8 0.94
4953 7 0.94
5136 9 0.94
5328 8 0.94
5484 9 0.96
5652 8 0.96
5808 10 0.96
5972 11 0.96
6121 12 0.96
4th gear
RPM Timing Deg O2's
4707 10 0.94
4859 8 0.96
4986 9 0.96
5136 9 0.96
5320 9 0.96
5476 8 0.96
5601 10 0.98
5828 11 0.98
5980 12 0.98
6171 14 0.98
Run#2
With Spray
3rd gear
RPM Timing Deg O2's
4804 11 0.94
5011 6 0.96
5167 8 0.94
5355 9 0.94
5527 8 0.94
5695 8 0.96
5875 10 0.96
5996 11 0.96
6156 12 0.96
6296 14 0.96
4th gear
RPM Timing Deg O2's
4910 7 0.96
5250 9 0.96
5343 8 0.96
5500 8 0.96
5644 8 0.96
5777 10 0.98
5859 10 0.96
6003 12 0.96
6203 13 0.96
6386 14 0.96
6503 16 0.96
Assuming that this car is tuned similar to DSM's o2's are a bit high and timing is too damn low. I would like to see someone elses numbers. Or maybe datalog someone in my area? Looks like Just an AFC will do a lot for this car. How far from the block is the o2 sensor in this car compared to 95-99 GST, is it safe to tune for 92 o2's and 20deg timing like in previous dsm's?
Peace out.
Old Jun 9, 2003 | 10:43 PM
AutoXer's Avatar
May I ask which system your logging with?
Old Jun 9, 2003 | 10:59 PM
OBDII Pocket logger v1.02h from Digital tuning
www.pocketlogger.com
peace out
Old Jun 9, 2003 | 11:33 PM
MalibuJack's Avatar
Are you using a wet or dry system? And is the car totally stock except for the Nitrous? I'm curious about using a small 35-50hp wet system in addition to my exhaust, boost controller (19-20psi), S-AFC..
Old Jun 9, 2003 | 11:34 PM
MalibuJack's Avatar
whoops.. Saw the totally stock comment.. Brain fart..
Old Jun 9, 2003 | 11:53 PM
I meant the IC spray, I dont see much difference in timing and o2's by using it and car felt the same. Maybe on a Dyno it will be a different story, but then again u wont have that air pressure pushing in the water against the IC at 100mph like on the streets.
Peace out
Old Jun 10, 2003 | 12:19 AM
n00dle's Avatar
Could you send some of your .pdb files to check out? Any wide open throttle runs will do. More parameters the better. qunajl@yahoo.com
thanks.
Old Jun 10, 2003 | 07:34 AM
MalibuJack's Avatar
Guess I'm a bit too eager to run nitrous on the car.. Read too much into your post.. The #'s didn't look right for a nitrous run.. LOL
Old Jun 10, 2003 | 04:29 PM
thanks.
Sent,
Peace out
Old Jun 10, 2003 | 04:54 PM
boostedwrx's Avatar
Man those timing numbers are low.
I recently data logged my car and was receiving 16 degrees of timing advance by 7000 rpm. You may want to try selecting fewer options when your loggin, as those timing numbers may not be accurate.... but then again it could be just a different car...
Those o2 voltages are also very very rich which does indicate how rich the stock evo is running..
Old Jun 10, 2003 | 05:38 PM
I will try it again tonight with just RPM's and timing, i did connect at 11s\sec but i heard of somebody connecting at 19-20? I will let the Byte timing run for longer tonight see if it goes Higher.
Also i never went as high as 7000rpms. but i'll see tonight.
peace out
Old Jun 10, 2003 | 07:01 PM
n00dle's Avatar
Got the files, thanks. I would do the opposite and log as many parameters as you can. I think 11 or 12 is the limit. Looking at your data I was curious to see what other factors were like TPS, Air Intake Temp, Coolant temp, etc. to try and get a bigger picture of what's going on. There's no advantage to just logging 1 or 2 parameters that I'm aware of, so log as much data as you can. If you can for logging....cruise in 3rd under 2k rpms and nail the throttle wide open to redline. This is the best way to log, under full throttle to redline. And if you can go right into 4th at WOT...
This is good stuff. Keep all of you logs for reference to compare to once you start modding you car out.
Old Jun 11, 2003 | 01:48 AM
I went out tonight and forgot the PL at home. but wednesday night i'll do some more testing for sure. Intake temp sounds interesting ......
Peace out
Old Aug 7, 2003 | 11:03 AM
Dale_K's Avatar
Will the data loggers show boost?
These dataloggers look pretty cool. Since the EVO lacks a boost gauge, I want to get something to show boost levels, etc. Since not every ODBII car is boosted I wonder if boost is one of the loggable parameters.
Is MAP the same as boost?
Old Aug 7, 2003 | 05:36 PM
No u dont get boost with pocketlogger,
Timing,RPM,02 (1), 02 (2), water temp , STFT, LTFT, TPS, i cant remember all of them
Laterz
Lightsaber
11
Nov 3, 2015 08:17 AM
SeanV
Nov 23, 2009 09:05 AM
Ted B
Apr 29, 2009 01:26 PM
04Evo8RS
Apr 1, 2005 08:09 PM
PiNG
Feb 27, 2005 04:19 AM
