F$@# high prices build your own Intercooler:)
240, you are using numbers for core sizes that you are making up, not the ones we are actually using. Nowhere did I put the dimensions out there you used for your example. Besides that I can't stand you so I have no desire to discuss anything with you, well if you get a terminal illness I'd talk about that
There's another one for your signature.
http://www.dvdtfab.com/intercoolertestlab.pdf
For those interested in the design of endtanks. While most just built a box and stick a tube in the end for shortest IC pipe routing, this guy found a properly designed end tank can increase performance quite nicely. I did some searching around for people using his coolers and found a post somewhere that his endtank design netted 18whp over the classic welded box tank design using the same core. He has a cooler for the evo8 but you have to cut the heck out of the bumper to make it fit.
TopLevelPerformance
26
Apr 9, 2015 08:15 PM
