2 Problems in less than 5 min!!
Old May 28, 2007 | 04:14 PM
Neuspeed06's Avatar
Angry 2 Problems in less than 5 min!!
So today was a nice day weatherwise, so i took a short drive around town. As i accelerated to get onto the freeway, *BANG* car sputtered and lost all power. First reaction i said to myself, "gotta be the IC piping" Got to the side of the road, and popped the hood, sure enough the IC piping was off. So quickly i tightened the clamp down, and that was that. So got back into the car, and put it in reverse to back up, and what do u know, reverse is locked out!! I CANNOT get it into reverse, no matter what i do, just grinds, or pops out. NOTE: I just got the ACT street clutch installed last week, and Ive been babying it till 500 miles. 477 so far. So i just drove it home and parked it. Problem, i park at a port that you HAVE to back out of, so any advice how this happened or a quick fix, please let me know thanks!
Old May 28, 2007 | 06:01 PM
sekula's Avatar
Problems have been known to exist with the ACT clutches and their engagement. Check under your hood to make sure all the shifter cables and linkage are fine and nothing popped off or whatever.
Old May 28, 2007 | 06:04 PM
evrblazin's Avatar
I know you prolly did this but just in case try going from 1st to reverse, 1st to reverse
that always works if Im locked out / grind
Old May 28, 2007 | 06:06 PM
glgz's Avatar
Just a thought but try to put in reverse with motor off and start it while in reverse. It may work to get you backed up to get out of the car port. Beyond that maybe the clutch just needs adjusted?
Old May 28, 2007 | 06:08 PM
sl0ev0's Avatar
maybe you gotta adjust your clutch pedal
Old May 28, 2007 | 06:11 PM
mrbkkt1's Avatar
was it a lower IC pipe that blew? maybe something got stuck in the linkage.
Old May 28, 2007 | 06:55 PM
scottatyamaha's Avatar
Souds like you need to adjust your clutch pedal.
http://evomoto.com/tech_info.php?tPa...d70f0370191ac5
Old May 29, 2007 | 09:13 AM
Neuspeed06's Avatar
^I have seen that write up before, and i will try that this evening. If it is still locked up, then I will take it back to the shop where it was installed. Thanks for the input everyone.
Old May 29, 2007 | 09:15 AM
trjx24's Avatar
i have the 5 speed and when i have a problem i put it in 5th then back into reverse. that usually works for me.
Old May 29, 2007 | 09:28 AM
denolloyd's Avatar
1st to reverse always works for me...
Old May 29, 2007 | 02:06 PM
Neuspeed06's Avatar
Have tried both of those suggestions, but it just will not engage into reverse. It will pop into a spot like its in reverse, but as soon as i let the clutch out, it grinds or pops out. I will try to do the clutch adj asap, but until then i might get stuck somewhere without being able to back up!
05VIII
16
Nov 18, 2022 03:38 PM
jmsrt4
23
Jan 30, 2014 02:10 PM
LimeEVO11
11
Nov 26, 2011 09:53 PM
pettyboy69
Dec 18, 2010 01:30 PM
SuperchargedGTZ
Aug 31, 2010 08:52 PM
