View Poll Results: Head studs yay or nay
Get them. Cheap safety net
116
59.18%
No need at this point. Keep the extra money
80
40.82%
Voters: 196. You may not vote on this poll
Honestly heads studs or not
Old Jun 9, 2007 | 02:05 PM
  #76
Evo8yurAMG's Avatar
Originally Posted by TTP Engineering
That is the point.
They are not needed at his modification level and WAYYYYYYYY beyond.
The arguement is not that the bolts are stronger than ARP stud and nut combo.
The arguement is that the upgrade is not needed.
ahhh...ok well then i agree with you...
what would you say is a good HP level to start seriously thinking about headstuds...im gonna be running a T04R soon putting down about 400WHP on pump and alot more on meth...
Old Jun 9, 2007 | 02:19 PM
  #77
NWRacingscene's Avatar
I installed mine 6 months ago (1X1), with no sort of oil/coolant leak, running a GT30 28psi, blah blah.. Yes, the right way would be pulling the head, but I heard people being successful in doing the 1X1 way also, so I went that route, and everything seems fine *knocks on wood...
Correct me if I am wrong, I thought it would be helpful to leave as much as you can hanging of the head (intake/exhaust manifold, turbo, etc, etc) to keep the head "seated" as much as possible without movement...
Just my 2 cents
Good luck either way
Old Jun 9, 2007 | 02:28 PM
  #78
TTP Engineering's Avatar
Unless you have your head off the car for a build or you are pushing over 550whp, studs are not necessary to protect your car from a MYTH that has been busted.
The recommendation was posted on the last page... Here it is above.
Old Jun 9, 2007 | 02:30 PM
  #79
Evo8yurAMG's Avatar
what do you mean its helpful to leave as much hanging of the head? not saying your wrong, i just have no idea what you mean
Old Jun 9, 2007 | 02:32 PM
  #80
Evo8yurAMG's Avatar
gracias
Old Jun 9, 2007 | 10:10 PM
  #81
DsmAwdTurbo's Avatar
Originally Posted by ElectricEvoIX
please pardon my stupidity, can someone please describe briefly "pulling the head" just want to get an idea of what that entails exactly. Not that I would be doing it myself just some knowledge i'd like to gain, thanks
Pulling the head.
Draining coolant.
Taking the upper ic pipe off of the TB
taking battery out.
Removing pass side motor mount to access timing belt,
taking timing belt off,
taking bolts out of intake manifold stay (bolts the block to the intake manifold)
there is more but thats just like the basics. its not a bad job Takes 1.5 hours or so to get the head off
maybe 2
-Anthony
Old Jun 10, 2007 | 07:35 AM
  #82
Originally Posted by DsmAwdTurbo
Pulling the head.
Draining coolant.
taking battery out.
maybe 2
-Anthony
1.5-2 hrs with 2 people that know what they are doing.
6 hours or more for the rest.
It would help you remove the head if you removed the head bolts, exhaust manifold to turbo bolts, oil feed line, radiator, 10mm coolant turbo feed line, engine wiring harness, injectors clips, IAC harness, TPS clip, throttle cable, intake ground, MAP sensor clip, knock sensor clip, vacuum lines and various other connections.
Old Jun 10, 2007 | 11:26 AM
  #83
Exciting News's Avatar
I think he means leaving the components attached to the head on the head because their weight will keep the head "seated" for the 1x1 method.
Old Jun 10, 2007 | 11:46 AM
  #84
Bonestock!'s Avatar
Thanks TTP for clearing that up.
Old Jun 10, 2007 | 06:42 PM
  #85
DynoFlash's Avatar
get em !
Old Jun 10, 2007 | 06:54 PM
  #86
Don't get em!
Old Jun 10, 2007 | 07:46 PM
  #87
4rcd6's Avatar
LOL! Scott or Al?!?! Hmmmm who to choose...choose wisely.............. rofl
Old Jun 10, 2007 | 08:01 PM
  #88
The funny part is TTP is the retailer of ARP headstuds. If we are telling you they are not needed while we would love to sell a set, that should tell you something.
  #89
EFIxMR's Avatar
I done the one by one method on both my EVO's and I have no leaks whatsoever.
It gives me the confidence to push my cars to 33 psi on my stock evo 9 turbo and 31 psi on my big trim GT30...
Without headstuds I personally would not push my cars that hard.
Old Jun 10, 2007 | 08:42 PM
  #90
EVIL_EV0's Avatar
I bet the fastest players didn't use the 1x1 method on their cars.
