What milage should i change Sparkplugs at?
Ive got an Evo 9 with 22k miles on it
Mods include:
TXS TBE
MBC
255 walbro fuel pump
K&N Cold air intake
Boosting at 22-23 psi
Tuned by Innovative tunning
I do 2-3 track days a year and 3-5 auto x's as well, also its my daily driver
I know the recommended specs say 60k miles but was wondering what you guys think and have done
Thanx in advanced
Mods include:
TXS TBE
MBC
K&N Cold air intake
Thanx in advanced
You change them when they need to be changed, its that simple. Keep an extra set at the house in case they foul out/or you start misfiring. Takes only ~10minutes to change if that!
personally i change them more often! my car has only 8400 miles and i am on my third set of plugs including the factory ones...
1st change was made at around 5000 miles
2nd change was made at 8300 miles
3rd change will be made at 10000 miles along with all car fluids (tranny, radiator, etc etc...)
i remmeber before someone posted a pdf link that showed what needed to be changed and at what intervales. showed manufactures suggestion for both normal driving and aggressive. anyone have that link anywhere i looked all over for it and couldnt find anything.
If you intend to only race your car at the 1/4 track and run leaded c16 in it, then you may want to consider changing them on a more regular basis. I am planning to change my plugs and O2 sensor at every oil change.
My old DSM I bought a couple sets of NGK BPR7ES plugs. I kept a set in the glove box to change if need be. I think I only went through maybe two sets of plugs the whole time I had the car witch was close to about a year. I always ran the car at 22+lbs of boost on 100 octane and gapped them around 0.23. Never had a issue.
As for Iridium plugs. I never could justify spending 30-40 bucks for a set of plugs when they aren't going to make THAT big of a difference over a cheap set of NGK. I mean for what you pay for one set of Iridium plugs you could have 3-4 sets of NGK.
AMSBuilt4g64
Mid-Atlantic Region
11
May 6, 2010 01:38 PM
