Evo 8 ACT Clutch Noise
Old May 11, 2009, 08:30 AM
  #61
SuperchargedGTZ's Avatar
My setup...ACT 2900 prostreet flywheel and I love the engagement and everything else.
now this can be a different problem, but ever since I had the clutch/flywheel installed, my car vibrates like crazy when i make hard turns in 1st gear at very low mph. when i disengage the clutch pedal, the vibrations goes away.
Any suggestions?
Old May 11, 2009, 09:48 AM
  #62
Any suggestions?
BUMP....anyone
Old May 12, 2009, 04:10 AM
  #63
Any suggestions?
anyone??
Old Oct 12, 2011, 09:04 AM
  #64
manss's Avatar
stock evo clutch is bad? stock clutch is better than most of those aftermarket ones. it went out after two weeks? that was obviously your first car with standard transmission. If youre not way past stock on whp then i say you go get a stock clutch. I cant believe your clutch went out in 2 weeks. SMH! return your evo
Old Oct 12, 2011, 11:11 PM
  #65
Registered User
ChanseEvo8's Avatar
^^^ Newbie....... SMH! Bringing a thread back to life only to bash another won't do you any good
Old Jan 14, 2013, 07:29 PM
  #66
Mr Wong's Avatar
This is not my video. but I have the similar issue with my 03.
I have an ACT 2900 HD and un-sprung 6 puck disc. and Street Lite flywheel.
this only occur in first gear leaving from a stop. Is this normal or no? i hear that its stress cracks around the flywheel bolts. please correct me if im wrong.
Old Jan 14, 2013, 10:28 PM
  #67
akqowns's Avatar
^^ I got same clutch and exactly same happens to me. It could hear from 2,3 rd gear occasionally , but mostly moving the car from reverse to 1st gear. I think it's normal for 6 puck unsprung... and act clutch is kinda annoying for DD.. thinking to get a stock clutch..
captinnitro
Feb 24, 2016 10:03 AM
Ians06
Jul 25, 2015 08:16 PM
WartheSecond
Lancer Tranny/Drivetrain Tech
Jun 15, 2015 05:48 AM
gasolinebaptism
13
Jan 4, 2014 05:07 PM
Alacris
Aug 17, 2005 05:38 AM
Quick Reply: Evo 8 ACT Clutch Noise
