O2 housing questions
Old Jul 15, 2007 | 12:47 PM
Thegame's Avatar
Okay, so I'm in the market for an O2 housing... The question I have is this. Do you retain the stock donut gasket with an aftermarket O2 housing? I don't see how you can if the outlet is bigger??? I'm mainly interested in titek. I don't run a 3'' dp, I run the HKS which is like 2.65'' so I want to make sure this will work. Thanks.
Old Jul 15, 2007 | 01:37 PM
pulley1fan's Avatar
You CAN reuse the stock donut gasket, but you should buy a new OEM one from Mitsu or somewhere like Lancershop. The fitment will be the same as the O2 outlet and the connection to the DP are always the same. I run a stock O2 on a 3" Megan DP and it fits perfect.
Old Jul 18, 2007 | 07:38 PM
insanechief's Avatar
im going to pput in a MR turbo 02 housing with a helix DP should i go get a new donut gasket before i dig into my car?
Old Jul 18, 2007 | 07:42 PM
sabastian458's Avatar
there isnt a diff in the mr and the gsr o2 housings. buy an ebay special stainless housing. they also come with all the gaskets you need.
the part off the mr that i think you are refering to is the turbo exhaust hotside. the part the housing bolts to
Old Jul 18, 2007 | 09:40 PM
MasterNater's Avatar
Actually, I've seen a couple websites that list the MR O2 housing as an upgrade for the GSR's. I've always wondered if there was a difference.
Old Jul 18, 2007 | 09:44 PM
Evo Tengoku's Avatar
by MR, I think they mean Megan Racing. . .
Old Jul 18, 2007 | 10:02 PM
Ph3n1x's Avatar
The Megan Racing o2 Hosuing has shown some of the highest gains for prolly the lowest price.
Why spend unnecessary money.
Old Jul 19, 2007 | 07:26 AM
BigBallin's Avatar
because with megan you are hit and miss with their 02 housing. why not just spend the extra 50 bucks to start and get a titek. way better quality
Old Jul 19, 2007 | 12:42 PM
Luis@TTP's Avatar
the megan racing is just as good i have not ha to replace any of the stock doughnut gaskets also use the stock o2 housing steel gasket we have MR o2 housings in stock
Old Jul 23, 2007 | 11:52 AM
Thegame's Avatar
Thanks for all the responses, but the main question I have still stands... The stock O2 housing uses a doughnut gasket and the O2 housing outlet is 2.XX ". I have learned that aftermarket O2 housings retain the stock doughnut gasket. (Buy a new one, whatever.) My question is this... How is the aftermarket O2 housing with a larger diameter outlet, able to retain the same size doughnut gasket??? My first thoughts are, "It can't." Please tell me the real answer. I just got my Titek today. I do not have an extra doughnut gasket laying around to answer my own question. Thanks.
IX_MR
Jan 16, 2013 07:44 PM
Hi Im Vinh
Oct 11, 2009 09:28 PM
ep3a2
Sep 14, 2009 02:13 PM
vassago
Jun 16, 2009 09:05 PM
EVO8LTW
64
Oct 20, 2005 10:28 AM
