EVO Green, 93 octane, 30 psi of boost and a dyno chart
Old Aug 30, 2007 | 05:26 AM
  #46
deadbeatrec's Avatar
Originally Posted by Exciting News
Placebo effect? There are those who'd say the same about BP or Sunoco. A published analysis of the major gasoline brands would be nice to see who may be fibbing about their product.
My buddy made 640whp on Wal-Mart gasoline! Dat stuff is da shizzle fo' sho'...
i always run sunaco because i feel the car runs the best but, a point here or there doesnt make 30 psi sound safe.
david, were there any counts of knock at all?
Old Aug 30, 2007 | 05:27 AM
  #47
Danner's Avatar
Originally Posted by Silk
Just out of curiosity.... Does having the AEM make tuning for high boost on pump gas easier then say with a stock ecu?
Old Aug 30, 2007 | 05:29 AM
  #48
Soon2BEVO's Avatar
Originally Posted by Blue Evo 8
After reading this thread about how great Shell V-Power 93 gas is I went out to look for some to put in my EVO and my beater, but the shell station was getting renovated.... so i had to settle for Exxon's 93 tonight.
By the way I was wondering is 93 gas from: Hess, Exxon, Aamoco/BP, Sunoco all the same?
I use Shell, Sunoco, Hess, and Exxon/Lukoil. All seem to be exactly the same. Ive never gotten a "bad tank of gas" like Al talks about every other post.
Old Aug 30, 2007 | 05:32 AM
  #49
djh's Avatar
djh
Originally Posted by deadbeatrec
i know some companies have different additives but they should all have the same effective octane of 93 or its false advertising.
Octane numbers are measured under specific conditions of temperature, carburetion (and I really mean carburetion), and RPM, which don't have a whole lot in common with modern engines. The rating system was designed in the 1930s. For example, the Research number is at 600 RPM, Motor at 900. So two fuels that have the same measured octane number may perform differently at high boost with an 11:1 AFR at 6000 RPM.
Dave
Old Aug 30, 2007 | 05:59 AM
  #50
9sec9's Avatar
David, tell Daniel congrats for me. The 20G-LT is a hell of a turbo and you and Robert did a great job of bringing it to the public. Now, as far as my own 3B (BUSCHUR BUILT BEAST), I'm afraid that tuning OKIX's car is going to be the closest I get to the track. I've got 4 or 5 people wanting to buy it and as you know, I have little time. Again, another great job on Daniel's car. You're still a DB though.
Old Aug 30, 2007 | 06:09 AM
  #51
JDMEvo9RS's Avatar
30psi on pumpgas? Come on...
Old Aug 30, 2007 | 06:12 AM
  #52
vwjeff's Avatar
Originally Posted by davidbuschur
BTW, my brother Daniel, who owns the car, did most of the tuning himself. He's been interested in learning the AEM and after about 4-5 hours of instruction last night he has a decent handle on it. .
HAHAHA thats funny cause he was telling me he wanted to learn tuning when I was up there last on the dyno. He asked me if it was hard to do
Congrats you 2
So Dave is Daniel gonna be a 1 stop shop
Old Aug 30, 2007 | 07:36 AM
  #53
David Buschur's Avatar
All 93 octane fuel is not the same, for sure. Gas stations are mostly dishonest if you ask me and there is no Federal or State standard in the state of Ohio that checks for octane. They check for contamination but there is no octane checking, no telling what you are getting most of the time.
Al saying he sees bad gasoline a lot is 100% true. DO NOT BUY GAS A VALERO IT IS 100% JUNK. Every single car I have had here that bought gas at Valero knocked like mad.
If we ran this car on 94 Sunoco from the other end of town it would pick up a MPH or two I am sure.
Old Aug 30, 2007 | 07:38 AM
  #54
I don't think Daniel is going to be a one stop shop. He wants to learn enough to move the revlimiter and make small timing/fuel adjustments. Says he doesn't care about the rest. Just make adjustments at the track while I am not there.
The compression of this engine is 8.8:1, it is NOT lower. We do not build any engines with compression ratios lower than they were stock.
Old Aug 30, 2007 | 07:41 AM
  #55
Sir Lancelot's Avatar
Hmmm, so FPGreen + 30psi = 377whp = Impressive?
Dont get me wrong those are great numbers but at the same time I made more than that on 93 pump gas with a 20g-9 5 with 8psi less boost
Dave, are these numbers truly that high for the turbo/mods on the car?
Old Aug 30, 2007 | 07:42 AM
  #56
Soon2BEVO's Avatar
I know Valero is junk and some other stations are sketchy like run down old Citgo stations. However, I think buying from the big guys like Exxon/Lukoil, Sunoco, Shell and Hess are very safe. I just think Al is ALWAYS referring to bad gas, but in CT it is mostly the big stations and I think he tends to really over do it on the bad gas example. I feel like he says it every 3 posts when I rarely hear any other tuners (including yourself!) say much about it if at all
Old Aug 30, 2007 | 07:45 AM
  #57
Soon2BEVO's Avatar
Um did you made your power on a low reading Mustang dyno?
  #58
gaulrich2003's Avatar
Why did David Lowe make 350whp on your dyno using pump gas with more mods? Did you just keep the boost down? If so, why?
  #59
yellowEVO21's Avatar
dave's numbers are from his infamously low-reading mustang dyno...your numbers are from a different dyno....apples to oranges comparison.
now are you still unimpressed?
Old Aug 30, 2007 | 09:48 AM
  #60
8thWonder's Avatar
It was a baseline run, G. 23 psi I believe. After that run, DB cranked everything up and turned on the alky.
