EVO Green, 93 octane, 30 psi of boost and a dyno chart
Old Aug 31, 2007 | 07:53 AM
  #76
yellowEVO21's Avatar
Originally Posted by High_PSI
MIKE1023 ran 30PSI of boost on Al's flash on his 2003 Evo (Stock Turbo) and ran at over 120MPH and low 11's. It can be done, just need time I guess for people to make it the norm.
with no alky at all on a flash? i doubt it.
Old Aug 31, 2007 | 09:41 AM
  #77
One Wicked EVO's Avatar
mike did run that no alky and now he get to look at his blown motor at home
Old Aug 31, 2007 | 09:55 AM
  #78
High_PSI's Avatar
Oh he DID eventually blow his motor huh? He beat the **** outa that car too
Old Aug 31, 2007 | 10:05 AM
  #79
High_PSI's Avatar
I am also wondering how well the IX would do with this turbo. Any High HP IX's with this turbo yet?
Old Aug 31, 2007 | 10:30 AM
  #80
Soon2BEVO's Avatar
Yeah I hear his motor is in peices now..
BTW, he had a 2005 EVO.
Old Aug 31, 2007 | 10:37 AM
  #81
joedr's Avatar
EvoM Moderator
ditto! I use only Shell 93 and used to run my car with 25 PSI. 0-3 knocks depending on how I handle the pull!
30 PSI.... I am not sue that I want to run that on Puerto Rico with freaking Temps at 90 and humidity 96+.
Congrats on the numbers!
Originally Posted by Spaceball 1
And people think im crazy when i run 25psi everyday on only Shell 93.
30psi nice!
My car starts to get a bit noisy at 25psi so i leave it there.
Old Aug 31, 2007 | 12:38 PM
  #82
David Buschur's Avatar
crap
Old Aug 31, 2007 | 12:39 PM
  #83
Martin,
I think I covered everything you've said already in this thread.........thanks for the input. One other things, since I caught hell, it's time for you to change your signature
Old Aug 31, 2007 | 12:43 PM
  #84
4G63 T's Avatar
Just Curious, here's what i have.
264/272
680 inj.
ix turbo on 03 evo
alcohol
ecu
Stock intercooler
supporting mods
366/366 on Mustang Dyno
Old Aug 31, 2007 | 12:44 PM
  #85
4G63 T's Avatar
Frogot.... 30 psi just like Brother Daniel
Old Aug 31, 2007 | 12:46 PM
  #86
what's your point?
you're running alky, he's not.
Old Aug 31, 2007 | 12:52 PM
  #87
4G63 T's Avatar
Originally Posted by yellowEVO21
what's your point?
He has more aggressive Cams, AEM and intercooler
Old Aug 31, 2007 | 12:54 PM
  #88
4G63 T's Avatar
Drop in piston, header...unless these are only bling bling
Old Aug 31, 2007 | 01:32 PM
  #89
Good example of the varying levels of pump gas......
We just finished a build on an EVO9, Stage 4, ported intake, 65 mm throttle body, Green, ported exhaust manifold, SS 02 housing, 3" downpipe, some else's 3" cat, someone else's catback, Cosworth cams and the AEM EMS.
I started tuning the car yesterday and I had a hell of a time tuning it. On pump gas couldn't make the power I wanted.
I then tuned the car on E85 and the car made great power, ended up at 394 whp at about 27 psi of boost.
The customer wanted to drive the car around on E85 and then on pump gas, double check the tune and make sure he was happy. (drove here from Chicago and didn't want to have to drive back)
After he was happy with the E85 he came back, we drained the tank and put 5 gallons of Shell 93 in it.
Him and I went for a drive in the car. The first time he floored it I was thinking "This car is a freaking turd, I can't believe we built it." I didn't way anything to him and I pulled up the log from the pull he just made. I noticed the knock count was completely different from before, as in non-existent. I told him, "That's very odd, the tune has completely changed since I tuned it yesterday." He tells me, "I got 93 octane on the turnpike yesterday, why is it different?" As soon as he said "turnpike" I knew what it was. I asked, "Was it at Valero?" He says, "Yes." I instantly added 4 degrees of timing, still no knock.
By the time it was done I was able to run an additional 7 degrees of timing and still have less knock counts than I did on the junk Valero gas.
The next few runs on the car were a blast, the additional timing completely transformed the car from a turd to a winner.
You do have to be careful tuning at these levels on pump gas, more so if you are changing brands.
STAY AWAY FROM VALERO for SURE
Old Aug 31, 2007 | 01:41 PM
  #90
Actually the pistons aren't bling bling but won't give more power. The engine is stock bore with 55,000 miles on it, same compression ratio as stock. Also not sure if the custom header I built is better than a stock manifold or not, questionable.
