EVO IX Oil Leak
Old Sep 24, 2007 | 05:14 PM
prEVOke's Avatar
EVO IX Oil Leak
I have an oil leak that seems to be coming from the back left side of the engine if you are looking at it from the front. The oil can be seen on the alternator and when i park up it drips down to stain the floor. I have had the car serviced at Steve Hill and they looked at they cleaned it all off, did a visual inspection and couldnt trace the source.
This weekend i had new rotors and pads fitted and again looked into the oil problem, i had the banjo bolts near the area changed and that has not resolved the issue either.
Does anyone have any ideas what may be causing the problem in that area? any suggestions welcome as i really need to resolve this, it has got steadily worse and now smoke simmers off when i stop at traffic lights so i'm keeping it off the road until its resolved
Old Sep 24, 2007 | 05:15 PM
CBRD's Avatar
is your valve cover leaking? pcv line off?
and make sure that not just the banjo for the oil feed for the intake cam gear is tight, but also the large hex fitting it goes into!
cb
Old Sep 24, 2007 | 05:16 PM
apagan01's Avatar
youre car is under warranty,,,, you have to speack to e service manager and demand the car to be fixed there is no BS with that
Old Sep 25, 2007 | 03:50 AM
prEVOke's Avatar
i'm in the UK car is a JDM Import, no warranty for me
CBRD thanks will check that tonight
Andy more ideas......
Old Sep 25, 2007 | 07:36 AM
sblvro's Avatar
how many miles/km in your evo? did anybody take the valve cover off. most leaks usually comes from the valve cover or the oil cap. the next thing I would check would be your steering fluid since the pump hose goes a long way from the back to the front on the left side. other than that it can be oil plugs, engine head gasket if it was replaced(modified). if you bought it new and was never serviced beyond maintenance then it must be something unusual.
Old Sep 25, 2007 | 02:59 PM
1killertsi's Avatar
Dude I had the same exact problem. When I was installing my injectors last night, the PCV hose was completely off.
Old Sep 27, 2007 | 05:56 PM
kaonashi's Avatar
Did you ever find out what was leaking? mine's leaking and i just got my valve cover powder coated but i cant see any leaks from the valve cover or head for that matter but there is quite a bit of oil on my altenator
Old Sep 28, 2007 | 06:04 AM
prEVOke's Avatar
no i couldnt find the solution so the car has been taken into a garage to be dignosed will post up the results
Old Sep 28, 2007 | 09:17 AM
kaonashi's Avatar
Ok, well i cant even find exsactly wher emy leak is coming from so today im going to pull all the timing cover's off and get some lights up in mine so i can pin point it.
Old Oct 18, 2007 | 11:16 AM
SwabeLife's Avatar
what's the result?
Mycarwontstart
Jan 21, 2017 09:48 PM
bluevilevo8
11
Sep 7, 2015 06:30 AM
evonewbeight
May 12, 2014 04:58 PM
EMHRACING
Jul 18, 2013 07:54 AM
Shinka
Jul 31, 2005 12:19 PM
