Need help, car won't start after breaking Exhaust O2 sensor
Old Sep 27, 2007 | 07:11 PM
tork's Avatar
hey fellow members. before i start going crazy replacing everything to fix the problem, i need some opinions.
it's a 2003 EVO VIII...
here's the story
i rolled over a small tree stump i didnt see. scraped my exhaust from the cat to the mid pipe. heard a thump, and car dies. try numerous times to restart it and nothing.
the only damage i see is the O2 sensor on the exhaust mid pipe which was cracked. no other damage to under body of the car what so ever.
so i replaced the O2 sensor thinking that would fix the problem. that wasnt the fix. now it still wont start.
i started thinking maybe the spark plugs went bad. but not sure if thats the problem.
anyhow i dont want to make it any longer, so what other things can contribute to this problems incase i'm over-looking something.
your insights would be greatly appreciated
Old Sep 27, 2007 | 07:19 PM
dsm25psi's Avatar
If that was the only damage done make sure your wire to the o2 sensor are not damaged or ripped apart, if you hit something hard enough to brake the sensor you defiantly want to check the connections.
Old Sep 27, 2007 | 07:39 PM
RoadSpike's Avatar
Probably shorted the heater wires and blew the fuse to the computer.
Check all your fuses
Old Sep 27, 2007 | 07:41 PM
tork's Avatar
i replaced the entire O2 sensor harness n all. n it still aint starting. pretty confused how the car wont start.
i looked up and down the entire underbody after replacing the sensor to see any other damages, and nothing. hmmm
Old Sep 27, 2007 | 07:43 PM
RoadSpike's Avatar
you did check your fuses right?
Old Sep 27, 2007 | 07:44 PM
tork's Avatar
road spike, i started thinking about maybe a fried ECU as well or like u said, burnt fuse. i'll check again
Old Sep 27, 2007 | 07:46 PM
RoadSpike's Avatar
Remember there are 2 fuse boxes one under your steering wheel and one under the hood.
Old Sep 27, 2007 | 07:50 PM
tork's Avatar
crap i forgot to check the fuse box under the steering wheel. i'll do that in the AM as well
Old Sep 28, 2007 | 04:11 PM
tork's Avatar
just an update to my problem
new O2 sensor + 20A fuse = my car starting again.
thanks for your help guys, much appreciated
Z_Lancer_Man
63
May 3, 2020 03:53 AM
rabit1132
May 2, 2015 06:18 AM
Missa25o
Lancer Troubleshooting
Feb 1, 2015 11:40 AM
fq340
Feb 16, 2009 07:33 AM
shunderwunder
Nov 30, 2007 04:11 PM
