Rear drive shaft removal
Old Oct 25, 2007 | 05:30 PM
lilman8403's Avatar
OK so here is the dilema. My goodridge passenger brake line has been rubbing on my halfshaft. so the cv boot has a big tear in it and is leaking grease. i am doing a new brake install so my caliper and rotor are already off. i removed the main axle nut but do what else do i need to remove to take out the half shaft?
any help would be appreciated.
Old Oct 25, 2007 | 05:36 PM
Sti THIS's Avatar
1)push on the half shaft to make sure it will silde through the hub easily (you should just be able to push on it with your palm.)
2) yuou have to unbolt one of the ball joints. I THINK it is the one where the upper control arm meets the knuckle. then sepperate the upper control arm from the knuckle
3) bend the knuckle slightly towards you and to towards the rear of the car and finagle the half shaft out of the hub
Old Oct 25, 2007 | 05:42 PM
lilman8403's Avatar
yes the half shaft does push easily. i can't seem to get the ball joint off of the knuckle!
Old Oct 25, 2007 | 06:01 PM
lilman8403's Avatar
any suggestions?
Old Oct 25, 2007 | 06:39 PM
lilman8403's Avatar
bump
Old Oct 26, 2007 | 06:36 AM
lilman8403's Avatar
morning bump
Old Oct 26, 2007 | 06:48 AM
ak47po's Avatar
Old Oct 26, 2007 | 07:10 AM
lilman8403's Avatar
thanx. that should be helpful. i will tackle it as soon as i get off.
Old Oct 26, 2007 | 08:22 AM
Sti THIS's Avatar
to get the ball joint off the knuckle, put the nut back on unitl it is flush with the top of the bolt, smack the nut with a hammer, this way you dont damage the threads
Old Oct 26, 2007 | 12:12 PM
lilman8403's Avatar
thanks STI, i will try that
Old Oct 26, 2007 | 04:21 PM
lilman8403's Avatar
okay, for the life of me none of the joints will come off of the knuckle. appreciate all of the help so far. I took off the sway bar mount to help. Any more suggestions would help a lot.
Old Oct 26, 2007 | 04:28 PM
lilman8403's Avatar
well i am going to see if a ball joint remover will work!
Old Oct 29, 2007 | 03:43 PM
lilman8403's Avatar
a friend told me that there are pinch bolts in the rear to remove the arms. is this accurate? i cannot find them. i want to make sure before i use the ball joint remover!!!
Old Oct 29, 2007 | 03:51 PM
lilman8403's Avatar
bump
Akito
Lancer How Tos / Installations
19
Dec 28, 2020 05:53 PM
4RETECH
11
Apr 10, 2013 10:42 PM
wazmunstr
23
Jan 30, 2011 06:23 PM
Nastynine
Apr 10, 2010 05:45 AM
EvoAlex48
Jul 25, 2009 02:56 PM
