Evo IX spark plugs
Old Nov 8, 2007 | 07:27 PM
ElectricEvoIX's Avatar
Evo IX spark plugs
I've done my searching and have read countless threads and am completely mis-directed. Now I felt the need to replace my stock IX plugs, and after reading and through research I opted for the NGK BPR7ES plugs. Now it seems that those plugs are only for the VIII and not for the IX. Now my questions are a) did I totally just fawk everything by putting those copper plugs in? b)what plug besides the stockers (ILFR7H) could I go with? (mods are in my sig)
Old Nov 8, 2007 | 08:19 PM
Most-Wanted's Avatar
Put the stock ILFR7H plugs in
Old Nov 8, 2007 | 08:39 PM
BURNALL_4's Avatar
Are those stock, or one step colder?
Im pretty sure those are colder.
Old Nov 8, 2007 | 08:47 PM
Tsurugi-san's Avatar
Denso sells a IX appropriate iridium plug --- you can buy a set from Nolimitmotorsports. WAY cheaper than the NGK's. I'm running them currently with absolutely ZERO issues.
Old Nov 8, 2007 | 08:52 PM
The ILFR7H are stock on the IX motor, just checked em as I put em BACK in 20 mins ago. The NGK's I had were for VIII's and were shorter than the IX plug. I will look into the denso one's as a possible replacment.
Old Nov 9, 2007 | 02:01 AM
PC325xi's Avatar
how often should I change my spark plugs, I also have an IX with similar mods to electricevoix
also which plugs do all the other IX owners out there run?
Old Nov 9, 2007 | 06:42 AM
well I found very valuable information after I started this thread From what's i've gathered any of these BPR7ES or BPR8ES plugs ARE A NO GO ON THE EVO IX!! I also put these pulgs on my car when I stumbled upon the valuable information. The VIII plugs and IX plugs are different. The length between the nut and the electrode differs by about 1.6 cm between the VIII and IX plugs. There are really no cheap alternatives besides the Denso's or the stock replacements (NGK ILFR7H)
Now for replacing them that's clearly on how you feel the car running?? Do you feel a rough idle or a misfire during higher rpm's?? You should check your plugs at least every oil change to see how they are. After putting my stockers BACK in last night I noticed they were getting more the black side so they are going to need replacing soon but at 11 bux a plug i'm holding off for another couple of weeks lol
Old Nov 9, 2007 | 06:50 AM
fugiwara's Avatar
what makes you think you need to change your plugs already?
Old Nov 9, 2007 | 06:52 AM
fugiwara's Avatar
step colder? are you sure you are an evo owner, it says 7, thats the stock heat range.
Old Nov 9, 2007 | 06:53 AM
saiyanzzrage's Avatar
denso ikh24 are one step colder for the ix's. I was running them when i had the meth
if no meth id put the stockers back in
Old Nov 9, 2007 | 06:56 AM
by the looks of them, looking like carbon buildup on them. I mean the car is running fine with no misfires that's why I said I'm going to hold off for a couple of weeks, prob even the winter if the car doesn't give me a problems. Not going to be boosting or any of that crazy nonsense in our lovely NJ-freeze-your-sack-off-weather. lol
Old Nov 9, 2007 | 07:01 AM
bigric09's Avatar
i have been running these same plugs forever... w/meth and without..... .they work great. Ive tried the ngk ILFR7H and LFR7AIX .... all 3 fit, the denso and the last plug are cheaper than the ILFR's .... I gap them at .024 for no meth and .022 for with. No issues with any of these settings as of yet
Old Nov 10, 2007 | 06:26 AM
FastAzzEvo's Avatar
haha, so which ones did you like better? and how often ya'll changing spark plugs...
Old Nov 10, 2007 | 04:20 PM
bigric09's Avatar
for my mod level... the 1 step colder seemed to work better.... for your mod level, id say you are ready for them ...
Old Nov 11, 2007 | 04:07 AM
FastAzzEvo's Avatar
Lfr7aix?
