Evo IX spark plugs
Old Sep 9, 2009 | 03:41 PM
  #76
kaj's Avatar
kaj
But when I close the gap (my plugs came at .045), the iridiun pad no longer sets over the electrode. It's off to the side.
Old Sep 9, 2009 | 03:47 PM
  #77
kaj's Avatar
kaj
Never mind. I worked some magic. All lined up. :-)
Old Sep 9, 2009 | 04:12 PM
  #78
tweaker41's Avatar
Alright. I'm pretty sure you said that you had ordered IKH24's. Those come gapped at .032 and so do the IKH22 and 27's. Are you sure you got the right plugs. The IKH20s come gapped at .044 but that is a STI/ many other vehicles plug.
Old Sep 9, 2009 | 04:31 PM
  #79
kaj's Avatar
kaj
If anyone is in a pinch, you use Autolite Iridium xp5325.it's the correct length and cross references with ikh24.
I'm using them until my ikh24 get here. Gapped at .024. Stock engine, etc. Runs great, so far.
Old Sep 9, 2009 | 05:42 PM
  #80
kaj's Avatar
kaj
Ah. My bad. I shoulda clarified: I'm running the Autolite plug as it's the ONLY one in my whole town that x-references with ANY of the plugs listed above. I'll be swapping in the Densos as soon as they arrive.
Old Sep 21, 2009 | 10:58 PM
  #81
cangriracing's Avatar
i got some autolites and they suck, 24 pounds boost they were just as bad as my worn out densos, then i lowered the boost that helped for a bit but it got bad again. Just ordered those ikh22s hope these finally work
Old Oct 12, 2009 | 08:44 AM
  #82
TouringBubble's Avatar
I think the Autolites are hotter than stock. The stock Autolite heat range should be a 4 from what I've gathered ... not much info out there on it though. Cross reference the BPR7ES from the VIII as a comparison with Autolite heat ranges (the last digit is the heat range ... lower is colder).
Old Nov 23, 2009 | 09:11 PM
  #83
PC325xi's Avatar
how many miles are you guys seeing before replacing your plugs for your ix?
Old Mar 1, 2011 | 04:27 PM
  #84
mx4life85's Avatar
I'm only getting about 8-10K miles before having to change my plugs. I do it about twice a year, or every other oil change.
Deanooo
Aug 25, 2016 05:17 AM
D1andonlyantman
Nov 11, 2015 12:53 PM
Done
210
Apr 4, 2015 10:47 PM
brakeboost980
26
Apr 3, 2015 02:17 AM
4G63_EVO
Jul 3, 2013 04:51 PM
