View Poll Results: Did Mitsubishi screw up on the clutch?
Yes, You screwed the pooch
483
61.69%
No, The clutch is fine.
300
38.31%
Voters: 783. You may not vote on this poll
Did Mitsu screw up on the clutch
Old Sep 16, 2003 | 11:28 AM
  #256
90GSX-03EVO's Avatar
Flywheel....
Old Sep 16, 2003 | 11:29 AM
  #257
Pressure plate...
Old Sep 16, 2003 | 11:31 AM
  #258
Pressure plate again....
Old Sep 16, 2003 | 11:32 AM
  #259
If ACTMan is still around, I would like his input on this comparison.
Thanks,
Josh
Old Sep 16, 2003 | 11:58 AM
  #260
ACTman's Avatar
Thanks,
Josh
Wow, now that's real COOKED!! I am not sure if I agree that one is abused and the other is not but for sure this one is severe. Which one are you comparing to?
Old Sep 16, 2003 | 03:02 PM
  #261
Um.....I was comparing it to the one posted about a page back where the dude said that Mitsu said it was abuse and if he replaced it with an aftermarket setup, that they would push the bit red button and void all his drivetrain warranty. I guess that if you change to an aftermarket clutch setup, they will not warranty the factory fuel injectors anymore or something. I was just saying that the one I posted WAS abused, where the other one is pretty questionable.
The one I posted failed at 2400 miles. The guy had it at the drag strip, bone stock, doing 5,000 rpm launches. They said that he told them that he made about 5 or 6 hard launch passes on it and then it started slipping on his way home that night. Kinda makes you wonder why people still try to do this on the stock clutch, huh?
Oh, they also charged him $3,400 for the repair. The flywheel could not be resurfaced (obviously) and all three of these components had to be replaced (along with throw out bearing).
Josh
Old Sep 16, 2003 | 03:14 PM
  #262
ACTman's Avatar
Um.....I was comparing it to the one posted about a page back where the dude said that Mitsu said it was abuse and if he replaced it with an aftermarket setup, that they would push the bit red button and void all his drivetrain warranty. I was just saying that the one I posted WAS abused, where the other one is pretty questionable.
Oh, they also charged him $3,400 for the repair. Josh
The other one was definitely not as cooked but still looked like it had been overheated by the looks of the linings and surfaces. It was probably in smaller bursts but it still shows signs of overheating. BTW $3400 is rediculous!
Old Sep 16, 2003 | 04:37 PM
  #263
bpclements's Avatar
I think the clutch you are comparing to is mine. I can say that I have had around 15 good launches on it which ultimately caused it to fail. I think if you plan on launching on the clutch go ahead and start saving for an upgrade, if not, then I believe the stock unit will hold. Either way you will wear your clutch down on hard launches. Guess you have to make that decision between having a daily driver or not.
Old Sep 16, 2003 | 05:42 PM
  #264
Yep, that was the one I was comparing it to.
Of course, Hall Mitsubishi also was charging $36,000 or so for the 4 Evo's that they had there. Silver with big wing, black with big wing, white with little wing, yellow with little wing. Whit that kind of markup, I can see them charging $3400 for a clutch change.
I was just in there for the Pit Pass service because I was in the area and needed to get it done. They were really friendly and had great customer service, but the car prices were really too high.
Josh
Old Sep 16, 2003 | 05:57 PM
  #265
Noize's Avatar
EvoM Administrator
Disk and flywheel.....
Never in my life have I seen a clutch disc that is that fried. That is horrible.
Old Sep 16, 2003 | 06:19 PM
  #266
ACTman's Avatar
I have!! You don't want me to share photos, do you?
Old Sep 16, 2003 | 06:23 PM
  #267
As soon as I saw that clutch, I ran back over to my Evo and was so happy to see that my digital camera was still in it, stuffed under the passenger seat. I won't go in to details as to why it was in the back seat or what other pictures were on the memory stick. All I will say is that I was really happy that I could get some pictures of that grenaded clutch for you guys to see.
Josh
Old Sep 16, 2003 | 07:38 PM
  #268
QuickEvo's Avatar
Replacing mine right now @ 6200 miles, slipping very badly, just started today too. Bought an RMR to get me through the winter... Then the 2.2 monster will be built in the spring..... I do drive aggressively and my car is modded. So I think it would have lasted longer if I was easier on it, and had my car remained stock. But the people having to replace them at 2500 miles and below that is just absurd. really needs to do something about that.
Greg
Old Sep 16, 2003 | 07:57 PM
  #269
I think what needs to be done is people just need to learn how to drive the car at hand. AWD cars are not like other cars, and the Evo isn't really even like the DSM's. If you are going to modify, then you understand the "consequences" of leaving the stock clutch in place. If you leave it stock and you eat it up like the pictures that I posted, then you just don't know what you are doing and you deserve to be charged $3400 for repairs. That's just my opinion.
The Evo that had the clutch changed at 2400 miles that I posted was bone stock. He obviously was not driving properly and was abusing the car all to hell. I would also put money on it that he didn't even let the clutch get worn in before he started launching it. Oh well.
Until my clutch fails on me, I will continue to feel like it is just improper driving techniques. Once mine goes out, then I will say it is Mitsu's fault....hehehe
Josh
Old Sep 16, 2003 | 09:01 PM
  #270
Noize's Avatar
EvoM Administrator
Of course I do!! Hook us up!
