Redline Oil Vs. OEM
Old Dec 3, 2007 | 02:15 PM
  #46
GEARS's Avatar
All kinds of oil info here for those who race their EVO,
http://www.teamrip.com/faq.htm
Old Dec 3, 2007 | 08:07 PM
  #47
mrfred's Avatar
You mentioned some experience with Shockproof in the gearbox. Which flavor of Shockproof was that, and was it 100% Shockproof?
Old Dec 4, 2007 | 09:21 AM
  #48
GEARS's Avatar
PM me for some photos of the heavy paraffins being centrifuged out of the oil and building up in places.
Old Jul 12, 2008 | 07:59 AM
  #49
miragevo's Avatar
Veteran: Navy
Originally Posted by trinydex
this is a horrible question. redline makes an entire line of fluids, some of which will work in some of the drivetrain components.
what the hell is wrong with this forum? there's more than 10 of these drivetrain fluid threads, all in high page counts all full of horrible information recommending horrible things that are baseless.
is the stock fluid the best? if it was would you be able to put it in more than one component that classically "require" different special qualities? think about that one.
redline 75 90 NS will work in the rear diff. it has nice clutch type differential additive
redline heavy shockproof will work in the front transfer case. it's thick rasberry syrup.
in the 5 speed you can use redline mt90, mtl in certain combinations to get the desired consistency you want. some of this has to do with how often you race and what the local temperatures are if you daily drive.
I am placing an order for redline fluids for a 9 MR and was wondering why you chose 75 90 NS for the rear? the manual says I need a limited slip type fluid and the NS does not have it. The regular 75 90 has the friction modifier in it . Below is a technical paragraph from Redline that describes the differences. Let me know what you think.
"Red Line Gear Oils are designed to provide excellent low-temperature characteristics and improved gear protection at higher
temperatures. Red Line Gear Oils will reduce differential temperatures 10-70°F. Efficiency improvements between 1-5% are
typical. The synthetic base stocks used have tremendous thermal stability and provide the best film strength available. The
unique combination of base stocks and additives allow Red Line gear oils to carry higher loads compared to petroleum
lubricants. The stability of these products allow them to be used for extended periods. Red Line 75W90 Gear Oil provides
excellent protection in nearly all differentials, conventional and limited slip, in both racing and street use. 75W90NS and
75W140NS can be used in certain limited-slip units in racing to lock-up the differential. 80W140 should be used in commercial
hauling, problem limited-slip units, racing applications which see tremendous torque at low speeds, and where noise
deadening is desired. LightWeight or SuperLight can be used to obtain maximum power transfer in racing differentials which
do not see extremely high temperatures. If “chattering” occurs with any of these lubricants, Red Line Limited Slip Friction
Modifier can be used to eliminate the stick/slip action and reduce the noise. This additive should not be necessary in the
75W90 or the 80W140 Gear Oils, since they already contain this addtive, but in some units more is required. Too much friction
modifier can reduce the lockup in limited slip units, so it should only be used if needed."
Old Jul 13, 2008 | 10:50 PM
  #50
Hard Drive's Avatar
I suggest Amsoil FTW! You'll be good for 100k miles or 50k since it's "severe" conditions. Something to look into...
FlipSquad
Jul 24, 2017 03:21 PM
nuggetinu1
Feb 15, 2016 03:16 PM
polish_pounder
24
Oct 13, 2014 01:04 PM
Solo II Evo
Apr 22, 2009 03:08 PM
jdmr2
15
Oct 18, 2004 11:51 PM
