600AWHP with a 35r!?
Old Dec 5, 2007 | 07:01 PM
juice_evo_VII's Avatar
650AWHP with a 35r on Pump/Alky?
Looks like 600awp is possible given the 550hp combos DB has posted so then 650 has to be possible with a few higher mods?
Old Dec 5, 2007 | 07:02 PM
vaboostn33's Avatar
bump
Old Dec 5, 2007 | 07:09 PM
05blackevo8's Avatar
anyone?
Old Dec 5, 2007 | 07:10 PM
scorke's Avatar
Originally Posted by juice_evo_VII
Did a search looking for 35Rs hitting the 600awhp mark and I'm coming up short with the mod lists.
Thnx ahead of time.
Rez90.
You need a big hotside on it, standalone, good FMIC, good tuning, big cams.
Scorke
Old Dec 5, 2007 | 07:13 PM
denolloyd's Avatar
Originally Posted by scorke
Rez90.
Scorke
That and Race Gas should do it...
Old Dec 5, 2007 | 07:17 PM
Rez90.
Scorke
That will give it 37r like spool though eh?
Old Dec 5, 2007 | 07:19 PM
scorke's Avatar
What will having a FMIC good cams on a 37R do then?
Nobody buys a 35/37R to run it on stock cams, small intercooler, stock ecu....
Scorke
Old Dec 5, 2007 | 07:21 PM
ImprezvSE's Avatar
I have just the basics on a stock bottom end but I get full boost right about 5600-5700 and thats 30lbs.
Old Dec 5, 2007 | 07:26 PM
LT1runner's Avatar
Scorke
I'm planning on using the stock ECU and get close to 600 awhp.
Old Dec 5, 2007 | 07:30 PM
SloRice's Avatar
Here's a list of builds that made 550whp minimum on a Mustang Dyno. That's over 600whp on a Dynojet if you are just in it for the number.
https://www.evolutionm.net/forums/sh...d.php?t=307405
https://www.evolutionm.net/forums/sh...d.php?t=309141
https://www.evolutionm.net/forums/sh...d.php?t=264844
https://www.evolutionm.net/forums/sh...d.php?t=292258
https://www.evolutionm.net/forums/sh...d.php?t=272655
https://www.evolutionm.net/forums/sh...d.php?t=266647
https://www.evolutionm.net/forums/sh...d.php?t=268380
https://www.evolutionm.net/forums/sh...d.php?t=266098
Scorke
I have a 37, cosworth 272s, AMS tune doing 605@27psi right now, but I'm considering downgrading for faster spool if the 35r with supporting mods can hit the 600hp mark as well.
Old Dec 5, 2007 | 07:42 PM
O rly? Numbers game, no, I'm just not looking to loose anything up top with the downgraded turbo if I go that route.
Old Dec 5, 2007 | 08:05 PM
vaboostn33's Avatar
We shall see. This weekend will basically be the test. I basically have every supporting mod for the car to get tip top HP so we shall see.
Old Dec 6, 2007 | 03:33 PM
20Grockit's Avatar
if dave b. can do it then so can anybody else. i mean dave is hunting 700 on a 35r so i mean 600 is definately achievable.
Old Dec 6, 2007 | 03:37 PM
EvoDan2004's Avatar
i have the full race 35r and when the block is built i will be trying for 600WHP stock ecu using maf-translator... i have revovler cams. not really sure it thats big cam type. lol. i will be trying this on c16 and no holds bar here.
