FULL RACE TWIN SCROLL 30R results and data
Old Jan 3, 2008 | 11:08 AM
  #196
wilson1's Avatar
Thanks for the hardwork!
Old Jan 3, 2008 | 12:58 PM
  #197
Zeus's Avatar
Originally Posted by K Scorcz
One question I have is how come you aren't using Full Race's Vertical Intercooler with this setup. Wouldn't it aid in performance over the hyperflow intercooler since it was designed for this application?
What's more important is that this would show any advantages of the TS spool up/transient response without the ultra short vertical FMIC and piping. Otherwise it could easily be argued that all the response gains from the kit were from the FMIC design alone.
Can't figure out where I put Dan's number
Old Jan 3, 2008 | 01:48 PM
  #198
K Scorcz's Avatar
That makes sense then
Old Jan 3, 2008 | 01:53 PM
  #199
DS-03evo's Avatar
how did it do?
Old Jan 3, 2008 | 03:28 PM
  #200
Guerillah's Avatar
How did it do? Should be interesting!!
Old Jan 3, 2008 | 04:03 PM
  #201
LilRico's Avatar
+1
Old Jan 3, 2008 | 04:09 PM
  #202
EvoDan2004's Avatar
all the info should be up soon. just trying to fix some issues and get it dialed in. thats all i can say 4 now.
Old Jan 3, 2008 | 04:16 PM
  #203
04AWDTURBOEVO's Avatar
Evodan2004, your Wideband is out of Calibration on that Video.
Needs to be Calibrated, if you have not done it since then.
Old Jan 3, 2008 | 04:48 PM
  #204
EvoDan2004's Avatar
no its not.
Old Jan 3, 2008 | 05:49 PM
  #205
Originally Posted by evodan2004
no its not.
Ok.
I would not have sayed anything if I did not think it was off. And you are a fellow Jestr Tuned Member.
That is why I am going into all the trouble to prove it to you.
I am an expert on this Wideband. The Calibration is off. You can fix it very simply by doing a calibration in the morning before starting the car.
Or you can still think is good and leave it like it is.
When the Wideband blinks after getting off the gas and still in gear, the reading should allways be 20.9 until you resume or go into Neutral, as it is the right amount of Oxygen in the Air, meaning your Sensor is reading 20.9 percent of Oxygen as the car is in Vacum and sucking in fresh air from the outside.
Yours is blinking all over the place, as you can see in the picture.
I just looked at the Video a few times and noticed that. May be I am wrong, but looking at the image in the video, slowing it down and making a still frame of events taking place, that is how I came up with my conclusion.
Manie P.
Old Jan 3, 2008 | 06:28 PM
  #206
EvoDan2004's Avatar
well acorrding to innovate its right. and also my turner. and also many others its fine.
Old Jan 3, 2008 | 06:32 PM
  #207
EvoDan2004's Avatar
and i side note. im not off the gas but im not on it eather. look. im decelerating. but im not totaly off the gas. hard to explan. but the wideband is fine.
Old Jan 3, 2008 | 06:40 PM
  #208
broddey's Avatar
this thread needs a countdown clock so i can stop refreshing every 3 seconds. . .
Old Jan 3, 2008 | 06:42 PM
  #209
EvoDan2004's Avatar
ill be making a new thread bro. same thread name but 35r not 30r
Old Jan 3, 2008 | 07:34 PM
  #210
evodan2004well acorrding to innovate its right. and also my turner. and also many others its fine.
No problem, Man. I was just trying to help.
By the way, if you are partially on the Gas, like you say, the Wideband would reading in the 15's~16's A/F as there would be less Oxygen in the exhaust for the Wideband to read due to the fuel you are introducing and burning off while partially on the gas.
And, if you look at the picture sequence I posted, the Tach is going down in every frame, showing you are off the Gas too. All this is happening while your Wideband is also reading lower.
At any rate, have a nice day, Evodan2004, .
I can do this all day, , but I won't.
I am sorry I made you feel bad. It is what it is.
