FULL RACE TWIN SCROLL 30R results and data
Old Jan 9, 2008 | 01:00 PM
  #241
LilRico's Avatar
I hope you fix your car bro... I know JestR is looking foward in tuning your kit...
  #242
riceball777's Avatar
maybe you should get it tuned for the 35r.
i hope you get the problems fixed soon. i can really hear the surging when you hit full boost.
but hows the spool on the 35r compared to the 30r? Is there a noticable power differance?
Old Jan 9, 2008 | 01:02 PM
  #243
EvoDan2004's Avatar
i know the car needs to be tuned. but even john said it him self. tuning wont fix this type of surging im having. so i need to fix the issue befor serious tuning take place.
Old Jan 9, 2008 | 01:22 PM
  #244
l2r99gst's Avatar
evodan,
Quick question. Were you venting the valve cover with the 30r aswell?
Eric
Old Jan 9, 2008 | 01:25 PM
  #245
EvoDan2004's Avatar
Originally Posted by l2r99gst
evodan,
Eric
u mean that little red filter thinger. yes. the only thing and i mean only thing changed was the 30r turbo to a 35r thats it. i dident even change my diet or my interior lights.
i changed no settings from my 30r to my 35r
Old Jan 9, 2008 | 01:31 PM
  #246
l2r99gst's Avatar
Yes, that's what I meant. I know you said nothing but the turbo changed, but I just wanted to make sure. Venting your valve cover on a maf based car can cause fuel trim issues, especially at idle, letting unmetered air into the intake manifold.
The new turbo may have slightly different airflow at idle, making the adjustment of your DV necessary to keep the DV essentially functioning the same as was with the 30r, meaning the same open/closed postion(wherever it was at idle before). Venting your valve cover isn't helping the situation though. With a vented valve cover and a maf based car, once you adjust your DV past the point where it will be either open or closed at idle, then you are changing the airflow characteristics enough so that the breather hose now becomes a big source of unmetered air, causing idling issues.
Eric
Old Jan 9, 2008 | 01:40 PM
  #247
EvoDan2004's Avatar
i follow you on that. thank you for that info. so now that the bov is all the way - '' loose'' is still ok because it does not open or leak when i do boost testing to around 27psi
Old Jan 9, 2008 | 01:43 PM
  #248
l2r99gst's Avatar
I would say you are fine then. As long as it holds boost and idles fine with it loose, leave it as-is.
Now you just have to get your surging issue fixed. Does the 35r kit come with an anti-surge compressor cover?
Eric
Old Jan 9, 2008 | 01:45 PM
  #249
Speed Element's Avatar
Hey Geoff @ Full Race, YGPM!
  #250
EvoDan2004's Avatar
Eric
no it dident. i was told no need for it. now i think i need the damn thing.
today i played with cam timing and still no luck. still surges. if at all a change the surge seems to have moved up in the rpm. but im not really sure but it is still there.
Old Jan 9, 2008 | 01:52 PM
  #251
my 35r is at fp right now geting the hta wheel and cover changed
why dont you try putting an anti surge cover on there
Old Jan 9, 2008 | 01:54 PM
  #252
l2r99gst's Avatar
Well, I'm curious if it's real compressor surge or more issues with running a looser setting on your DV. I would have expected surge to be slightly lower in the RPM range and flutter there for a second or so, then continue on with boost. Although, I have no experience with this kit or 35Rs, so my guess may mean nothing.
I'm sure Geoff will chime in with what he thinks the issue is and suggest a solution.
Eric
Old Jan 9, 2008 | 01:55 PM
  #253
EvoDan2004's Avatar
i just might. dont have much funds to do so at this point but it might be where im heading
  #254
EvoDan2004's Avatar
Eric
i turned the bov tighter in one part of that vid. so to loose id say id dout it.
Old Jan 9, 2008 | 01:58 PM
  #255
EvoDan2004's Avatar
the surging seems to start at 4800ish and surges till 5800 maybe 6200 then smooths out. it does not happen for long at all.
